96 prelude SI clutch problems PLEASE HELP!!!
Old Mar 19, 2011 | 08:27 PM
preludelovr96's Avatar
Default 96 prelude SI clutch problems PLEASE HELP!!!
so I have replaced my slave cylinder and my master cylinder, I have also installed a steel braided clutch line bypassing the damper(line from master straight to slave cylinder). I bled the lines for forever, was not working. I got a hose and put it on the slave bleeder and put the other end in a cup of brake fluid and I left the bleeder open. I bled until the air was out, I got some pressure but not all. The pedal only has pressure for about half way on the bottom end. Any tips? am I doing anything wrong? why is the clutch not fully pressured, if there is no air in the lines and I know there isnt any leaks?
also, what do I do with the existing hard lines? are there plugs of some sort to fill the holes in the damper?
Please help guys and if you do thanx for your time.
autoxthis
Transmission & Drivetrain
Sep 18, 2008 12:50 PM
garyc17
Nov 8, 2006 08:32 PM
Panoply
Jun 19, 2006 06:45 PM
freshvibes
Mar 10, 2006 05:43 AM
IAluder95
Feb 2, 2006 07:45 PM
