honda prelude electrical problems
Old Mar 19, 2011 | 11:59 AM
caveshark's Avatar
Default honda prelude starting problems
Hi all, i am just after buying a 93' honda prelude 2.2 vtec and i am having problems with the car not starting , or after driving it around for hour the radio will stop and then all the dash lights will fade and the car will die away and wont restart,its like it doesnt have the power to crank over till the next day starts fine, the person that sold it to me said if this happens just unplug the two grey plugs that come out of the distributor and reconect them then wait 5mins then it will start, does anyone have any ideas as to what it could be ?
ps i am new to this site so hope this post is in the right thread or something
Old Mar 22, 2011 | 06:26 AM
1GPlusSH's Avatar
Default Re: honda prelude electrical problems
if you unplug the two grey plugs, will it crank even after it dies?
sounds like your alternator is losing charging power. do you have a way of checking it?
Old Mar 22, 2011 | 04:17 PM
caveshark's Avatar
it still cranks after i have unplug the two gray plugs for a bit then no power to crank but then when left a while it will then start, i took it to my local mechanic he hooked up computer to it and said all the problems were comming from the distributor so i went and got secondhand one from scrap yard and fitted it but battery was flat so will try it tomrro, any idea on how to testing the alternator ? i am thinking that putting a multmeter on the battery when car is running and it should tell if its charging,
ps i will post up results tomrro
Old Mar 22, 2011 | 08:55 PM
JUNlemonPrelude's Avatar
Download the manual, have a friend or someone help you also. Someone to rev the engine at different rpms to test the load and output. Using a multimeter should be fine.
Old Mar 23, 2011 | 03:29 AM
1GPlusSH's Avatar
not sure how it is in ireland, but local auto parts stores have equipment to test battery and alternator. i'm surprised your mechanic didn't test it.
hopefully, it's just your distributor. did he tell you what was up with it? getting too hot or what?
Old Mar 23, 2011 | 04:30 PM
caveshark's Avatar
ok fitted other distributor and car started fine so i ran it for a while then started it again everthing fine, till i went to start it later and i stalled it and she wouldnt restart it would just crank very fast but no fire up, left it for 30mins and then she started again....this has my head wrecked as to what it could be, i tested the battary when car was runing it was putting out 14.71 volts.........ok so its not the distributor so what next ?
Old Mar 23, 2011 | 08:19 PM
Hondasalesman's Avatar
Try your main relay I had an integra that did the same thing. After 3 250 dollar distribs it was a50 dollar main relay
Old Mar 24, 2011 | 09:06 AM
1GPlusSH's Avatar
^^ yes
Old Mar 24, 2011 | 09:47 AM
jarol220's Avatar
agreed you should also check and make sure there are no lose or corroded grounds I had that problem after an engine swap and it was a lose ground on my tranny.
Old Mar 24, 2011 | 10:40 AM
caveshark's Avatar
ok i took off the main relay and looked for ware but everthing looked good but thats not to say its working properly so i think i will buy a new relay to be safe, and tomrro i will check all the grounds as well, i will post up results later,
thanks guys
William Deese
Honda CR-V & Element
Oct 27, 2017 08:20 PM
Raevyn67
Aug 23, 2013 01:42 PM
dirtykeg
Feb 25, 2007 07:42 PM
skydragon786
Mar 4, 2006 09:44 AM
FFP
Nov 2, 2005 11:35 PM
