Garage Sale // Civic Integra OEM / Aftermarket // EG DC EK EJ!!
Selling pretty much everything in my garage and basement, so I can finish a couple projects..Spring is coming, so it's time to get things moving. EVERYTHING MUST GO!! If you're interested in a few parts, we can work out a deal.
Send TEXTS to 856-952-0859 // I don't frequent this board as much as I used too, so my PMs are basically useless.
- EG Single Cam Shift Linkage - $50
- OBD1 Integra LS OEM Fuel Injectors - $40
- BNIB Megan Racing 2.5' Test Pipe (Civic / Integra) - $50
- DSeries starter - $40
- DSeries Alternator - $40
- 92-95 Civic Coupe OEM Passenger Side Fender - $20
- 92-95 Civic EX Fuel Pump - $25
- 92-95 Civic Corner Lamps - $20
- 92-95 Civic coupe trunklid ( 2 small dings ) [Teal in color] - $50
- 92-95 Civic EX Gauge cluster w/ tachometer - $60
- B Series Custom N1 Crank Pulley (Shaved and counter-balanced by a local machine shop) - $50
- B16A stock Crank Pulley - $20
- OBD-2 B18C1 OEM Water Pump (50k miles ) - $25
- OBD-2 B18C1 OEM Oil Pump (50k miles ) - $30
- 2000 Civic SI Brake Calipers - $75 for the pair
- 92-95 Civic EX OEM Brake Master Cylinder - $25
- (2) DC Integra Power Steering Pumps - $30 / per
- EJ8 Civic Power Steering Pump - $30
- EJ6 Civic Power Steering Pump - $30
- 99-00 EK Civic Steering Column w/ ignition switch & key (Blown Air Bag) -$60
- EK Ignition switch w/ key - $40
- 92-95 Civic Coupe OEM Rear Bumper (Teal) - $40
- 92-95 Civic DEPO Drivers side head light, MINT - $15
- OBD1 JDM ITR OEM Intake Manifold - $50
- DSeries Throttle Body - $20
- (2) BSeries Throttle Body - $40/p
- Waffle LS Valve Cover - $30
- 99 Integra LS 5spd ECU - $50
- 97 Integra LS Automatic ECU - $40
- 99-00 Civic EX Auto ECU - $50
- Brand New in Box FAZE (Interchangeable Indiglo Colors) Air/Fuel Gauge - $20
**Pictures upon request!!
Hey what is the condition of Tokico Blues w/ Eibach Sportline (Red) Springs for EK - $175? How many miles were they used for? Whats the drop with the sportlines?
Mister Jew
Jan 30, 2008 09:01 AM
