UPDATED F22B2 DYNO #'S
Got it dynoed today after installing 2.25" catback exhaust - previous run with stock exhaust 131hp & 137tq. After exhaust 136hp & 141tq. Will post dyno sheet later.
Damn not bad.
You're running cams right and a hondata system, what kind of exhaust did you end up getting?.
I am assuming with the f22b1 and similiar set up I might be able to bump my power in 150 HP range.
This is crank HP or WHP?
bisi level 1 cam & phearable net ecu ended up buying a cheap exhaust on ebay which suprisingly sound nice and deep with no fitment issues. with a level 2 cam on a f22b1 your goals are reachable. My #'s at the wheel.
Nice. My guesstimated whp were 140 to the wheels with my Bisi Level 2 VTEC cam that I had; probably more cause the engine is pretty healthy. I should've dyno mine before I pulled it out for an H.
my tuner says i need to get an adjustable cam gear in order to hit 140hp but now i am trying to decide if go forced induction or h22 since have pass smog check every year.
Do both. Build a H22 boost. Thats a beastly build if you do it right. My good friend has a black 97' 4-door accord and he has it with a fully built boosted H22. It runs 10.9's all day
I see. At the time of my build of the F22B1, there's this seller that is selling $25.00 Geniune Skunk2 adjustable cam gear shipped because they were wayy over stock. It was a steal! So I got myself a red one.
Hey Adrbi, nice numbers. Im looking to do a bisi stage 2 cam in the near future too. With that cam and a good tune did you have any troubles passing smog? or would you have had in trouble if you havent smogged it yet?
I had to plug in the obd2 ecu and drive it until the readiness was set then took it in - no sniffer test they check for cat conv and thats it, if your state requires a sniff test i doubt you will be able to pass with a level 2 cam.
By sniffer test, do you mean when they put your car on the dyno to get emmissions reading, that's how it's done in PA.
Yes if thats the case I doubt you will get a level 2 cam to pass emissions readings. In my state obd2 cars they just connect the scan tool to check for any stored codes and a readiness check.
GonzoWerke
Jul 12, 2018 01:07 AM
TypeR-R6
Aug 17, 2002 10:18 PM
