Air Conditioning
Old Mar 18, 2011 | 04:48 PM
curtie94's Avatar
Default Air Conditioning
I just did a test where I grounded a wire and then jumped both wires together. This was on the sensor. I was wondering how do I read the sight glass if I can't start the A/C. Both times the A/C compresor started in the test. Which said Low Refigerent.
Old Mar 18, 2011 | 09:38 PM
chikin pickle's Avatar
Default Re: Air Conditioning
You need to get a volt meter. Check the continuity between the two pins on the a/c pressure switch. If there is continuity, then your refrigerant is low, or your switch is bad.
You cannot determine the a/c system pressure of refrigerant level by looking at the sight glass. You need to get a set of low/high gauges and measure.
Old Mar 19, 2011 | 02:46 AM
phootbag's Avatar
Evacuate and recharge the system. Diagnose the leak.
Old Mar 20, 2011 | 11:48 AM
75aces's Avatar
Check your AC valves. I had refrigerant replaced and it was gone in a few weeks. discovered one of the ac valves was leaking.
DMorrison67
Aug 28, 2018 09:17 AM
Ajak
Jun 17, 2014 02:56 PM
TriniCB7
Sep 6, 2012 11:42 AM
91integraLSVTEC
Aug 22, 2005 08:18 PM
tegbuilder
Jul 16, 2004 04:36 AM
