A/c Issues
Old Sep 6, 2012 | 07:45 AM
TriniCB7's Avatar
Default A/c Issues
Whats the easiest way to test the compressor on a 93 Accord? Aç blows fine, just not cold.
Old Sep 6, 2012 | 08:13 AM
v4lu3s's Avatar
RTFM
Default Re: A/c Issues
if its not cold its not blowing fine. the a/c IS the cold, the blowing is just the blower fan.
you need a set of manifold gauges with proper fittings for your car, and you will need to measure pressure on the high and low side to determine what the charge is and what the effectiveness of the compressor is.
Old Sep 6, 2012 | 11:42 AM
tim73's Avatar
Did it just start not working? First see if the compressor is engaging. If it is not, check the solenoid fuse. if it is good, then I would find the low pressure switch, and jump it out. If that makes the compressor spin, then youve either got a bad switch, or more likely you are low on refrigerant.
pirrello
14
Aug 11, 2017 07:13 PM
dsmil
May 30, 2017 09:46 PM
billybobdad
Mar 2, 2013 01:33 AM
jdadams12
Jul 13, 2006 08:05 AM
Cjsls
Sep 29, 2004 02:14 PM
