1992 Honda accord lx problems with starting that I can't seem to solve
Old Mar 18, 2011 | 04:43 PM
dmc3262's Avatar
Default 1992 Honda accord lx problems with starting that I can't seem to solve
I have a 1992 honda accord that has me stumped. Sometimes it will start and run with no problems, sometimes it will just turn over and not start at all. Here's what we have replaced so far, main relay, timing belt, plugs, plug wires, distributor, and fuel pump. We just don't know where to go next. It is usually getting plenty of fuel, but sometimes it's not. Is there more than one relay for the fuel pump? Any ideas of what to try next?
Old Mar 19, 2011 | 12:55 AM
holmesnmanny's Avatar
Default Re: 1992 Honda accord lx problems with starting that I can't seem to solve
Check for spark. If not, it could be the coil.
Old Apr 11, 2011 | 11:30 PM
navcc's Avatar
Hi, did u replace with a brand new main relay? I think it's possible that there is a hair line crack inside solder joint of the pcb. It's best to open the main relay and then ckeck for crack in the solder by using a magnifying glass.
If any hairline crack found then resolder it and your main relay should be fine.
In hot weather the hair line crack gets bigger, hence it cuts out the circuit.
I had the same problem years ago, I resolder my main relay and working great.
Old Apr 11, 2011 | 11:35 PM
slomofo's Avatar
GDD Member
He made one post a month ago, I'm pretty sure he's long gone.
moo32moo32
May 16, 2011 01:36 PM
cellblock
May 14, 2011 12:07 PM
ralbach
Classic Hondas
Dec 1, 2009 07:36 AM
instructor74
Sep 21, 2006 11:12 AM
1baddcivicsi
Aug 9, 2006 09:21 AM
