JDM B16a OBD0 Distributor/start up problem
Old Mar 18, 2011 | 07:12 AM
RanCRX's Avatar
Default JDM B16a OBD0 Distributor/start up problem
Howdy,
I recently had a bad dizzy due to the bearing/shaft seizing in the dizzy. I replaced the dizzy with a new one and everything hooked up fine and everything.
But I still have the same issue, its cranking really fast but not starting, very fast winding.
The dizzy is flush with the head.
The only thing I didn't do was set the first cylinder to top dead center before installing the dizzy. But I heard I didn't need to do that.
Also, I'm not sure if I have any spark. Or is it maybe because its flooding?
I have no codes flashing in the ecu besides the one flash at start up.
Don't see any fuses dealing with the distributor. Battery and Ignition fuses look good.
Any recommendations?
Old Mar 18, 2011 | 07:14 AM
tunerEF9's Avatar
Default Re: JDM B16a OBD0 Distributor/start up problem
Originally Posted by RanCRX
Howdy,
ur timing is off i bet u skipped a tooth double check the cams and crank...
Old Mar 18, 2011 | 07:24 AM
RanCRX's Avatar
So I had to set the #1 piston to TDC? I didn't do that, I just took out the old dizzy and slapped on the distributor where I had it parked.
Old Mar 18, 2011 | 07:49 AM
RanCRX's Avatar
Crap, your right. The intake cam and exhaust came are off. ****
Old Mar 18, 2011 | 08:55 AM
tunerEF9's Avatar
yep sounds right happen to me way to many times good luck hope it runs fine...
Old Mar 18, 2011 | 09:49 AM
RanCRX's Avatar
Just wondering. If my valves were bent. Wouldn't you hear a clunk? Or wouldn't you not be able to to rotate the crankshaft pulley?
Old Mar 18, 2011 | 11:56 AM
tunerEF9's Avatar
put ur crank at tdc then try and turn ur cams they should turn normal if one is bent it wont turn easy and might make some noise ull know
Old Mar 21, 2011 | 03:12 PM
RanCRX's Avatar
I grabbed a 1/2 inch drive and a 19mm at the crank pulley bolt and it twists around fine. Of course with the regular resistance but it does not get stuck or feel harder to rotate than before. I also don't hear any noise.
When the distributor shaft bearing seized the car just simply shut off as if I turned it off, there was no mechanical noises, no banging etc.
I hope the valve train is alright. Supposively I can do a compression test, but would it give the same readings if the timing is off?
I believe the last time I did a compression test, I was getting about 250-280 in each cylinder
Last edited by RanCRX; Mar 21, 2011 at 03:14 PM. Reason: I believe the last time I did a compression test, I was getting about 250-280 in each cylinder
SLIM NOTHING
Sep 8, 2010 09:37 AM
Slo_RSX
May 11, 2009 05:06 PM
E_F_9
Jan 2, 2007 12:43 PM
