code 17 b20b 00 civic si
I have a few problems with my car this one is getting annoying though. every once in awhile when im driving the car would be unresponsive.. I would push down on the pedal and get little to no response for a few seconds then the car would kick in but after that check engine light would come on. I jumped the ecu and got code 17 obd1. my question is how do i fix that? also the speedometer works fine.
Are you sure it's code 17 and not codes 1 and 7? Which would be primary O2 sensor and throttle position sensor codes. That sounds more like your problem areas.
weird today i was driving and speedometer started acting up!!! ughhhhhhhh
speedometer failing
http://www.youtube.com/watch?v=lAk1wDRQlVM
check engine code.. sorry my dog is crying in the background
http://www.youtube.com/watch?v=yZZ4FErZyqw
speedometer failing
ok so my car did the no gas thing again today i was on the highway driving 80 and the car started decelerating... i push the gas pedal to the floor and nothing.. i had to keep pumping the pedal before I got acceleration again.. it did it 2 more times after that and no check engine light... im not to sure what that is...
gulftiresinc
Aug 9, 2004 09:01 PM
celph.
Dec 7, 2003 06:40 PM
