EG Scraping Ground?
Old Mar 17, 2011 | 02:19 PM
KPowerSquadron's Avatar
Default EG Scraping Ground?
I have a 93 EG Hatch and its stock height, stock suspension
when i go around an uphill roundabout, i heard some scraping
..probably the tail pipe, but was wondering what you guys think it could be?
Old Mar 17, 2011 | 02:21 PM
grumblemarc's Avatar
The Grumpiest
Default Re: EG Scraping Ground?
Did you examine the tailpipe for scraping?
Old Mar 17, 2011 | 02:40 PM
i havent lifted the car to check under yet, but i dont see any scratches sitting normally
Old Mar 17, 2011 | 03:03 PM
The Grumpiest
Aftermarket header? You won't be able to tell until you get underneath the car.
Old Mar 17, 2011 | 03:18 PM
Rylan's Avatar
Sometimes your cat will hit too, it's normal to scrape. These cars arent that high from the factory.
Old Mar 17, 2011 | 03:21 PM
The Grumpiest
I still don't think anything should be scraping with stock height/suspension. I don't scrape. Never have with any of the Honda's I have owned.
Old Mar 17, 2011 | 03:54 PM
EternalSessions's Avatar
when/if you lift it up make sure all your exhaust brackets are there and have the rubber mounts attached. a missing mount will cause the exhaust to "sag"
Old Mar 18, 2011 | 10:25 AM
No sagging rubber mounts
looked under the car and tailpipe does indeed have a bit of scratching on the tip...
stock headers with the jdm b18c spec r
JJW
15
Dec 27, 2018 08:09 AM
caraudiowiz
Nov 17, 2014 08:44 PM
jorgenov30
May 30, 2011 10:58 PM
crazyguy
Sep 8, 2007 08:34 AM
