JDM ITR 5-lug conversion on a civic Si...
Old Sep 26, 2002 | 07:16 PM
Lenthrax's Avatar
Default JDM ITR 5-lug conversion on a civic Si...
does any one know if it is a direct fit?
i heard the axle's ends are different sizes..like the JDM axles are
36 mm and the USDM are 32 mm...
let me know if anyone had problems doing it...
thanks
jonas's Avatar
Default Re: JDM ITR 5-lug conversion on a civic Si... (skunk2allmotorSi)
yes.
get a USDM one then.
Old Sep 26, 2002 | 08:49 PM
Lenthrax's Avatar
Default Re: JDM ITR 5-lug conversion on a civic Si... (jonas)
if i have the JDM conversion which is 36mm.is it going to fit my stock si 32 mm axles?
i don't understand..
sorry
Old Sep 27, 2002 | 04:08 AM
darkknightwong's Avatar
Hey Dude...
GET a USDM ITR 5 Lug Conversion.
the USDM 32mm Axles DO NOT!!! fit the JDM 5lug Hubs.
I ran into this!!!
Here is my SI ....
https://honda-tech.com/zerothread?id=272699
Good Luck
DK
Old Sep 27, 2002 | 12:49 PM
chameleon's Avatar
Default Re: JDM ITR 5-lug conversion on a civic Si... (darkknightwong)
damn, good thing i just saw this, i was about to get JDM ITR 5 lug conversion with shocks and all that ..damn, so is there anyway to readily get jdm itr axles? that are 32mm ? hmmm
Old Sep 27, 2002 | 02:16 PM
R you serious's Avatar
Default Re: JDM ITR 5-lug conversion on a civic Si... (chameleon)
it depends what year spec the swap is offa.
Old Sep 27, 2002 | 02:21 PM
Reid's Avatar
Global Moderator
Default Re: JDM ITR 5-lug conversion on a civic Si... (R you serious)
No it doesn't.
ALL 98+ JDM ITRs had 5 lug and all had 36mm axles.
ALL USDM ITR had 5 lug with 32mm axles.
Old Sep 27, 2002 | 02:26 PM
Lenthrax's Avatar
Default Re: JDM ITR 5-lug conversion on a civic Si... (Reid)
awww...man too late...i have the JDM conversion..now what?
Old Sep 27, 2002 | 02:59 PM
eg6ajk's Avatar
all 98-01 SpecR ITRs (in JDM land) used the 36mm axle nut and larger axles on the outside. JDM CTR came with ITR specs axles.
the cure for the JDM axles, is using the CRV outer joints with 94-00 b-series axles.
a friend of mine did this on a DA (93) integra, there was much more work as hubs need to be machined to the DA knuckles in the front.
Old Sep 27, 2002 | 08:36 PM
Well to be honest..
Your F*cked... like me..
I ended up getting USDM GSR Knuckles, New Bearing, USDM 5 lug hub.
I used the JDM Caliper, and rotor, and caliper bracket.
DK
jc2801
Jun 7, 2007 10:05 AM
l2p
Jun 11, 2004 07:27 AM
RareSI
Dec 4, 2003 01:48 PM
Lenthrax
Sep 27, 2002 02:50 PM
darkknightwong
Jul 18, 2002 02:22 PM
