KMOD RSX 2011 285whp K24a1 Build-Pics Inside
Old Mar 17, 2011 | 02:46 AM
KeseK24RSX's Avatar
Default KMOD RSX 2011 285whp K24a1 Build-Pics Inside
We are nearly completed w/ our new build for the KMOD RSX. The trans rebuild is done(new Synchrotech carbon synchros), The head has been ported, Supertech valvesprings/reatiners installed, Supertech valves installed, the bottom end assembled w/ Supertech 12.5:1 pistons-Eagle rods, a k20a2 oil pump moddified & installed, the engine has been degreed, & the piston to valve clearances checked. We are just waiting on our custom intake manifold from GATO Performance, and we still have to build a custom header, & exhaust. After we get the results of these Crower Cams we will be testing the Kelford stage2 cams, then a set of Blueprint stage3's.
Here are some pics of our progress so far--
For More pics and specs go to->>http://www.kmodperformance.com/KMOD-RSX-2011.html
Old Mar 17, 2011 | 07:24 AM
KeseK24RSX's Avatar
Default Re: KMOD RSX 2011 285whp K24a1 Build-Pics Inside
KMOD K24 RSX 2011 Build
KMOD Ported K24a1 Cylinder Head
Eagle rods
Supertech 12.5:1 pistons(polished & de-burred piston crowns)
Crower Stage 2 3/4 Cams
Supertech Beehive Valves Springs
Supertech Spring Seats
Old Mar 17, 2011 | 05:07 PM
KeseK24RSX's Avatar
more pics
K24 w/ 12.5:1 Supertech Pistons
Skunk2 Adjutable Exhaust Cam Gear & K20a2 Intake VTC Gear
Degreeing Cams and Checking Piston To Valve Clearances
Old Mar 17, 2011 | 05:52 PM
KeseK24RSX's Avatar
Transmission Rebuild
Synchrotech Carbon Lined Synchros
Honda Factory Synchro-Left Synchrotech Carbon Synchro-Right
Countershaft Being Rebuilt w/ New 2nd Gear and New Synchros
Transmission Almost Done
Transmission Rebuilt & Fully Assembled
Up next- Final engine assembly, & mate trans to engine. Install engine/trans into the KMOD RSX
Old Mar 18, 2011 | 08:09 PM
KeseK24RSX's Avatar
Engine is fully assembled, valves adjusted, & Fluidampr crank pulley installed. Tomorrow we will be bolting on the trans and installing it back in the car. Looks like we will not have the GATO Performance manifold in time for our track tuning session on Thurs. We'll just have to run it w/ the PRC manifold & K20a2 TB for now. The best pass w/ our old set-up(internally stock K24a4) was a 13.48@101 expecting 12.90s out of our RSX w/ this motor.
Old Mar 19, 2011 | 10:02 AM
David @ Synchrotech's Avatar
Looks good!
Old Mar 19, 2011 | 07:01 PM
STRATTON's Avatar
nice build.
maybe i missed it what did the stock internaled k24 lay down ?
you want to hit 12.9 with full interior ?
stratton.
Old Mar 20, 2011 | 05:03 AM
KeseK24RSX's Avatar
The internally stock KMOD stg.1 Engine(k24a4 w/ cams & bolt-ons) made 220+whp.
Yes we are shooting for 12.90s w/ full interior, A/C & Power Steering. Its a true street car. I drive it everyday to and from work.
KMOD Performance.com
Old Mar 20, 2011 | 05:41 AM
KeseK24RSX's Avatar
Looks like we will be waiting a few more days before we bolt on the trans. We found an issue w/ the clutch disk, and had to order a new one.
Here is the engine as it sits now. (The stock valvecover is on it, so the pretty one does not get scratched during installation) My wife spent a-lot of time on that valvecover making it look good, & she would kill me if I damaged it. LOL
Track times and dyno #s coming soon. we will be testing the GATO Performance intake manifold(as soon as we get it-its been 4weeks), and a set of Kelford 179-b(stg.2) Cams
We are also prototyping our KMOD 4-1 DC5 Header.
For more pics and specs go to
KMOD Painted Valvecover(Midnight Pearl Black-same color as the car)
Old Mar 24, 2011 | 11:42 AM
KeseK24RSX's Avatar
New clutch came in today, & the trans is bolted to the engine.
Engine/trans install, Engine break in street, dyno , & track tuning coming next.
Anyone going to the IFO event at Rockingham Dragway(NC) on April 3rd? Hope to see yall there.
Behind my engine on the engine stand is a 600hp 408 LS3 for my wifes truck(02 Blazer Extreme)
My 1st V8, I cant wait for the Tq. 500lbs tq @ 2000rpm, should be fun.
Old Mar 24, 2011 | 02:47 PM
Mike@K-Tuned's Avatar
Good looking build. What clutch are you planning to use?
Old Mar 24, 2011 | 04:03 PM
KeseK24RSX's Avatar
Its a custom clutch that we're going to test. It was made for us by one of the big clutch companies.(three letters) Trying to find a way to make the 2nd gear last longer. Went all year w/o any issues on my other clutch. So we're getting close.
Engine/Trans installed. woo hoo. Happy Happy
Old Mar 25, 2011 | 05:48 PM
flesh199's Avatar
just for info for you man.You are not 50 degree safe with a set of bp stage 3 camshaft.My p2v clearance with this cam and wiseco piston is about 0.060 with a tsx 25 degree cam gear.
Just giving the info
Old Mar 26, 2011 | 01:27 AM
KeseK24RSX's Avatar
Thanks for the info. W/ just these Crower stg 2 3/4 at 32deg VTC we had .080 p2v so w/ the much bigger Blueprint-3s I'm sure it"ll be less.
We wired in the RDX injectors last night, & got her up & running last night.
Startup vid coming soon. These cams are def much bigger than the 02 type-s Cams we were running. We had to add a bunch of fuel all over the place. Should be on the Dyno Wed. & at the track on Thurs.
KMOD-Kese
Old Mar 26, 2011 | 04:48 AM
The Ogre's Avatar
very curious to see what it makes!
Old Mar 26, 2011 | 04:59 AM
KeseK24RSX's Avatar
still waiting on our GATO Manifold,& our KMOD header won't be ready b4 Wed. So I'm going to dyno w/ the PRC Manifold, K20 TB ,& a modified DC Sprorts header on Wed. What do you guys think we are going to make? Predictions please.
We had to order a new shift arm for the trans. It didnt feel right going into gear so we took it out, measured it, & it came in below spec. Spec min was 16.9mm ,& it measured in at 16.7mm. Plus the ends were worn down. So we ordered a new one.
KMOD-Kese
Old Mar 26, 2011 | 10:12 AM
K20EF8's Avatar
Are you sure with piston domes that size your compression is 12.5:1? I cant remember but does the A1 head have a larger chamber volume?
Old Mar 26, 2011 | 10:23 AM
KeseK24RSX's Avatar
May be a tad over 12.5 we opened up the chamber a bit ,& did a little work to the pistons ,but it should be close. Due to time constraints we never got a chance to do final cc-ing on the chambers.
KMOD-Kese
Old Mar 26, 2011 | 11:10 PM
K20EF8's Avatar
KMOD-Kese
They just look much higher to me, apparently 12.5:1 CPs in a K24
yours
Look like 12.5 with an 86mm stroke to me... 14.5 with 99
Either way nice build
Old Mar 27, 2011 | 12:04 AM
The Ogre's Avatar
yeah def ^
Old Mar 28, 2011 | 04:25 PM
flesh199's Avatar
yeah K20EF8 good info...I just realise that my 12.5 wiseco dont look like the op piston too
edit 87.5mm bore stock 99 stroke k24a1 block
Old Mar 28, 2011 | 05:01 PM
Nice progress. You are moving along pretty quickly.
Good luck on the dyno Wednesday.
Old Mar 28, 2011 | 05:48 PM
KeseK24RSX's Avatar
Thanks. We are trying to make it to the Import Face Off event on the 4th at Rockingham Dragway(NC).
Plans are Dyno Tuning on Wed, Track Tuning on Thurs , & Racing on Sun.
Old Mar 29, 2011 | 06:27 PM
Have you used the Synchrotech synchros on any other cars yet?
I have been browsing around their site lately.
Looks like they have some quality trans parts.
Old Mar 30, 2011 | 03:12 AM
yosolo's Avatar
nice built man
