High flow cat
I just took out the oem cat. from my 02' accord 4cyl.
break two socket wrench heads and two big *** cut on my fingers.
for those have aftermarket high flow cat.
is the aftermarket Cat come with a 02 sensor slot?
because i am picking mine up tomorrow.
if it doesnt come with the slot what can i do with the sensor?
[Modified by ArchAngel Sabastian, 10:41 PM 9/26/2002]
Random should have the bung welded into them, if not youll need to have the old bung from your CAT cut and welded into the new one.
sorry to asking the same sh_t again, for the sake of not messing up sh_t again.
If i bypass the sensor, the sensor should locate behind the hi flow cat right?
how far do i need to place it back?
if you bypass it your not sticking it in the cat homeslice,
here read
http://home.insightbb.com/~niedejb/o2.html
here read
You can get to the cabin from the underside... no big deal.
Put the sensor in the cabin of your car. That way you won't throw a code either.
i dont really get the idea
i just wrap that sucka with foil and slip it in the interior of my car?
what the sensor do anyway?
will i run lean on fuel or anything if the light is on?
sorry to be annoying but iam a newbie at this stuff.
thx
thx
Never said anything about the foil or putting it on the interior.
Heres what I did: http://home.insightbb.com/~niedejb/o2.html
The sensor makes sure the cat is reducing emissions (i.e. no longer "scrubbing" exhaust gasses. It has nothing to do with running lean.
tronic
Mar 14, 2011 06:45 AM
TypeRRRR
Aug 5, 2002 04:40 AM
