Car dies while driving (sputters then dies)
Old Mar 16, 2011 | 07:05 PM
BlueIntegraBoy's Avatar
Default Car dies while driving (sputters then dies)
Some of you may know, I am no where near my R. I left the R with my GF and her family to store and run it once in a while when I am in school. The following is what they described to me:
They took the car out for a drive and they said it started up fine. At one point during the drive at a stoplight, they noticed the tach needle bouncing up and down to redline (engine did not follow), but the engine started sputtering and then died. I guess they tried starting the car again, it ran for a little bit but sputtered and died again.
This is all the info I have from them. Any ideas?
Old Mar 17, 2011 | 08:02 AM
ekswapdude's Avatar
Default Re: Car dies while driving (sputters then dies)
its your fuel filter is what is seems to me. im on my 6th and 7th honda and the very few occasions this has happened to me it was always the fuel filter. once the car dies and the fuel is not being pushed through, the gunk has time to settle allowing more fuel to pass. once the car starts running again... the fuel brings the gunk right back to filter, starving your motor causing it to die...
Old Mar 17, 2011 | 08:07 AM
Yeah, it might be it since the car has just been sitting for over a month without a start.
Old Mar 17, 2011 | 08:24 AM
guanacoracing's Avatar
Fuel filter issue sounds about right. I have to say, though, that we stored our R early December and did not start it until sometime in late January (over a month later) and it started right up.
Nick, keeps up posted on what you or your GF may be able to find out.
Old Mar 17, 2011 | 08:37 AM
I'm going to order one from Del Ray. It just sucks that I'm 6000+ miles away and I can't do anything about it.
I'm also a little worried about the tach bouncing problem. Electrical problems suck.
Old Mar 17, 2011 | 09:52 AM
Ultraspeed DC2's Avatar
Take your distributor cap off and dust cover, clean off the contacts and you also might have to compress the connectors so they're tight if they are loose.
Old Mar 18, 2011 | 06:01 PM
jawls's Avatar
I'm agreeing with everyone on the filter. That would definately make it sputter and die. And the idle problem could possibly be your IAC. But I wouldn't imagine your tach going up to redline. Or wait, did you say that the engine didn't rev up when the tach went up? Sorry, I was kind of confused. But if the motor revs up as well...I would check your IAC voltage. It should have a 5 volt reference, with the key in the on position. And it is possible you have a vacuum leak. A vacuum leak will make your idle rough and fluctuate. Again, this is if your motor rpms increase. Let me know. Good luck man.
Old Mar 18, 2011 | 06:14 PM
This is correct
Old Mar 18, 2011 | 06:21 PM
jawls's Avatar
Possible short to power somewhere in the electrical circuit? Cause the tach to fluctuate. I'm not sure man. I'll ask a few friends and see what they think. Find out how often it does it, and if they can pin point exactly when it is doing it. ex. idle, high idle, cruising etc.
Old Mar 18, 2011 | 06:54 PM
I will fix the clogged filter and work from there. Like I said, I'm far away from the R.
Old Apr 4, 2011 | 09:03 AM
Hey Nick: Did you or your GF figure out what was wrong?
Old Apr 4, 2011 | 09:43 AM
AllShowNoGo727's Avatar
I bet its something to do with the distributor.
Old Apr 4, 2011 | 11:59 AM
I think it's the conversion harness that I am using. When I first picked up the R, it came with an OBD2A-OBD1 harness that looked like crap. My GF's dad's friend looked at the car and said whenever he jiggled the harness, the engine started to sputter. Maybe the pins weren't connected well. I ordered a new conversion harness from Phearable, but it hasn't been installed yet.
As for the dizzy comment.. the dizzy is new.
Old Apr 5, 2011 | 10:27 AM
^ you say the dizzy is new as in an ebay/advanced/autzone new? swap a friends oem dizzy it does not hurt to try it out.
Old Apr 5, 2011 | 12:57 PM
DizzyKing
Old Apr 6, 2011 | 06:28 AM
EFsSuck's Avatar
bump!
same thing is happening with my beater right now but I don't see how a bad fuel filter is going to cause a tach to bounce around? that is an electrical/spark kinda thing...
Old Apr 6, 2011 | 07:50 AM
get RIGHT's Avatar
I had this same symptom about a year ago and it turned out to be bad spark plugs. I dont see it as a fuel filter issue at all.
Old Apr 6, 2011 | 07:54 AM
Tyrant_007's Avatar
I had a very similar issue with an old CRX SI I had. I installed a new distributor (Distributor King), and that fixed my problem. I was told the bearings went out in it. All I know is it fixed it. They make good distributors though, so i wouldn't think it would go bad that fast. Hopefully it's just your harness that you bought.
Old Apr 6, 2011 | 07:58 AM
JEBirdman's Avatar
That's a good suggestion and I agree that it prob wouldn't go bad so fast but there is a chance you just got a bad distributor. It happens sometimes... used 2004 2008 volkswagen gti r32 review in portland or
Old Apr 6, 2011 | 08:17 AM
Dave_B's Avatar
I hate distributor king dizzy's. Their CS and support sucks.
But first, try with another known good dizzy to see if that solves the problem.
The tach bouncing like that tells me it's electrical and not fuel starvation from a fuel filter. Most likely an EFI main, or dizzy.
<--- just bought a car, and EFI main harness was the culprit. Previous owner(s) installed a make shift kill switch and the connection was poor.
Old Apr 6, 2011 | 10:56 AM
Thanks for the suggestion guys. It's going to be a slow process since I am not physically at home to check out the R. But any updates and I will post here.
If it is the dizzy, I might just have to hold off on buying another one, but I think DizzyKing has a warranty.
Also, when my GF and her dad was checking out the car last week, they said it started and ran fine. Problem might be intermittent or a one time thing.
Old Apr 10, 2011 | 06:01 AM
creelgriffin's Avatar
I also am having an Acura engine problem but firstly my biggest issue is to know how to post or start a new post so I can get some inputs. Can you or anyone help me with instructions on how I can post a new topic for discussion about my Acura engine problem? Thank you. [Smile]
Old Apr 11, 2011 | 12:08 PM
GUILOTINE's Avatar
Kill Gil
Ignition issue is my guess
Old Apr 15, 2011 | 10:20 PM
spcrxracer's Avatar
I've had this problem once before. Turns out, the adjustable fuel pressure regulator I installed was internally defective (and I didn't know it). I swapped it back to the stock unit and car ran like a champ
Start with the fuel regulator and filter. Then move to ignition-related problems.
Old Apr 16, 2011 | 09:17 AM
TOO MUCH TORQUE's Avatar
a bouncing tachometer is the ignitor failing. good luck
