93 GSR running ROUGH after topend rebuild, PLEASE help
Ok Im posting this for a buddy. Here's whats been done:
*Head resurfaced after blown headgasket
*New timing belt (he says its completely perfect) and they didnt do anything with the service connector. He didnt know what that was.
*Cleaned IACV
*New top rings in the bottom end
Heres the issue: It takes about 1 min for it to crank and then once its cranked it sounds like a subaru up until about 3000RPMS then it runs ok. When he comes to a stop, it cuts off. What do you guys think the issue is? Should he do something different as far as adjusting the timing? He says all the marks line up but he hasnt jumper the service connector. Any feedback will be appreciated.
*Cleaned IACV
Yep, all that stuff, and jump the service connector like you should have before and put a timing light on it to check ignition timing.
Hey did you ever find out what the problem was with your motor. Im having the same symptoms on the same vehicle. 93 gsr with top and bottom end rebuild. my pcv valve broke and was replaced, knock sensor broke but havent replaced yet. map sensor is leaking by the t-fitting.
waciii
Oct 13, 2008 09:24 AM
GsrTurboCRX88
May 18, 2007 10:15 PM
prophetjinn
10
Jul 11, 2006 02:18 PM
