CRX si 5 speed trans to JDM D15B?
Old Mar 16, 2011 | 08:26 AM
kilassapsap's Avatar
Default CRX si 5 speed trans to JDM D15B?
So, im picking up this CRX si 5speed trans around chicago. He never told me what year is that. but this tranny has 5 speed clutch cable sellin it for $200.00
I have a 91 ef and a JDM D15B 4 speed. I took out the 4 speed trans and bought 5 speed trans came out of 96 civic. It wouldnt fit so i had to wait and this guy texted me offer his tranny.
Would it fit? Guy that helped me out here said it should from 89-91 civic hatch si. But this one is from CRX si unknown year. Im not sure. Scared to buy if its not gonna fit again. Right now i have 2 trannys. any ideas? help me out.. thanks in advance
Old Mar 16, 2011 | 08:33 AM
EF909's Avatar
Default Re: CRX si 5 speed trans to JDM D15B?
You could tell what year the tranny is from the groves on the shalf. 88 tranny has 0 groves. 89 has 1 grove and 90-91 has two grove.& depending what year the tranny is depends if it could fit your clutch. 89-91 tranny has 20 splines on the shalf so it should fit the clutch on your Ef with no promblem if its an 89-91 tranny. hoped this help
Old Mar 16, 2011 | 08:35 AM
24TEN's Avatar
PHANTOM MENACE
Go into the FAQ, TRANSMISSION AND AXLE, second thread. It will tell you what to look for. Also I'd like to assume you know but if you don't 88-91 transmissions are cable actuated. If you're looking at a hydraulic transmission then you may encounter the same problem with the last transmission.
Old Mar 16, 2011 | 08:46 AM
(. )( .)'s Avatar
that so granny with bolt up. just have to make sure the splines are currect for the axles.
Old Mar 16, 2011 | 11:24 AM
Yeah. i saw one picture.. but i forgot where it was. ima try to search for it. Thanks!
Old Mar 16, 2011 | 11:36 AM
Thanks that did help..
Old Mar 16, 2011 | 11:42 AM
Oh. Sh*t. forgot about that. So right now. I have the JDM D15B. i think its the USDM D15B7?? correct me if im wrong. But i think it would fit bcuz guy told me came out of 90 CRX si.
L3-1...... = 88/89 21 teeth clutch spline?
L3-2...... = 90/91 20 teeth clutch spline?
Saw this on the FAQ
Old Mar 17, 2011 | 01:30 PM
bignosewhipper's Avatar
^90 crx si = 26 splines
Old Mar 17, 2011 | 07:17 PM
^so it wont work? sorry. im just new here. but if u can help me. that would be awesome. I havent counted the splines yet.
HondaBryan43
Feb 10, 2009 08:48 AM
92gsrsupercharged
Sep 30, 2007 03:54 PM
b16a2-t *turbocoupe*
Jan 9, 2006 06:23 AM
91hatch_on17's
Dec 30, 2002 01:20 PM
CRX-TurboMan2
Jul 30, 2002 10:32 PM
