brake lines
so i ran new brake line in my 96 accord ex and i cant get the old lines out the union to put in the new ones to small of area to work and i dont want to take out my master cylinder so is there any way i can use a compression fitting or just plug the line some how just so i can get brakes or go rite to the abs moduler
i dont care how i do it i just want to be able to stop
You guys are such jerks! You made not one attempt to assist this guy. Who are you to belittle him and not even offer any help. This is why HT has a bad reputation.
There are many ways to remove fittings from tight spaces, if vice grips do not work, sometimes a pipe wrench will do it. Pipe wrenches can be purchased in very small sizes. I have a good number of tools at my disposal.
If you cannot get it taken care of your self, consider hiring a mobile mechanic to do it for you. Good luck
There is no easy compression fitting for brake lines. It will require a special flare tool and some special fittings which can be expensive if you do not have a good source for them. One place that you can try and find a mobile mechanic is in the Craigslist of your locality under services offered.
integrawow
Suspension & Brakes
Jun 15, 2010 01:27 AM
Nickb257
May 4, 2010 01:44 AM
Jake92eg
19
Apr 9, 2008 11:30 AM
