2001 motor mount question
Have a motor mount out, i think it is the motor trans mount, just need to i.d. it to order it. you can see it between the engine and the firewall dead center of the vehicle. no bushing left at all, when you put it in gear you can see the engine mount move inside the housing. just hoping someone can verify the proper part name. not sure if it is a ex,le or what as far as the engine. will have to figure that out later. thanks for any help.
Rear engine mount, honda part numbers are below, top is for an automatic, bottom is for a manual.
50810-ST0-980 INSULATOR, RR. ENGINE MOUNTINGRUBBER (AT)
50810-ST7-000 INSULATOR, RR. ENGINE MOUNTINGRUBBER (MT)
fluke702
May 14, 2009 05:23 PM
balistic CRX
Dec 27, 2001 04:37 AM
