Broke a sensor, who knows what it is? 99 f23
Old Mar 15, 2011 | 12:48 PM
Jaz760's Avatar
Default Broke a sensor, who knows what it is? 99 f23
I broke a sensor that is underneath the intake manifold and right above the oil filter, does anyone know which sensor this is? Its the only one in the vecinity.
Old Mar 15, 2011 | 12:53 PM
GhostAccord's Avatar
Default Re: Broke a sensor, who knows what it is? 99 f23
Oil pressure sensor.
Old Mar 15, 2011 | 02:32 PM
Jaz760's Avatar
Oil pressure switch? Is that another name? Or knock sensor?
Old Mar 15, 2011 | 02:38 PM
HonBeer's Avatar
Like Ghost said. Oil pressure switch.
Old Mar 15, 2011 | 02:49 PM
Yes oil pressure switch is what I meant...... If you have both the pressure switch and knock sensor they are in the same area. However if you only have one sensor back there it would be the oil pressure switch. Depends on what trim level your Accord is DX/LX or EX
The oil pressure switch has a rubber boot that pulls off and the knock sensor uses a plastic locking connector.
Old Mar 15, 2011 | 04:34 PM
Jaz760's Avatar
its an LX, so i would have just the oil pressure switch?
Old Mar 15, 2011 | 04:41 PM
accordmatt's Avatar
yes lx should only have oil pressure switch. napa is ur best bet or honda l just did mine and autozone or advanced auto both charge like $80 and have to special order it. honda has it for around $30 and napa had it for $8. honda would be exact replacement napa is not but will work
crk112
May 29, 2012 10:00 AM
LOVEthatDC2
Aug 25, 2009 09:29 AM
drbenne
Jul 7, 2008 06:09 AM
SleeprCivic
Jun 21, 2003 02:07 AM
civic-si-2000
Jun 19, 2003 11:16 AM
