Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
H22 Build thread!!! MASTER PRICE SHEET!!! UNBELIEVABLE PACKAGE DEALS!!!
Old Mar 15, 2011 | 08:37 AM
RealStreet's Avatar
Default H22 Build thread!!! MASTER PRICE SHEET!!! UNBELIEVABLE PACKAGE DEALS!!!
Hello guys,
Our specialization here at Real Street Performance is engine building and the associated parts. We are not an accessory shop, there are far better places to buy your wings and your lips from, but if you need pistons, rods, valve springs, cams, turbos or anything that holds the engine together, helps make the power or helps get the power to the ground, we can probably help you.
I will list a lot of the parts we have for sale in this thread, if you need something that isnt shown here please PM me for an immediate response. OR please call us at 407-695-7223 and make sure to let us know you are from Honda-Tech.com You can also IM us on AIM at RealStreetSales or on MSN with sales@realstreetperformance.com which is also our direct email.
www.RealStreetPerformance.com
Phone1: 407-695-7223
AIM: RealStreetSales
Email: Sales@RealStreetPerformance.com
MSN: Sales@RealStreetPerformance.com
Everything in this thread is specific to the H22 Engines. As you guys know there is a ton of mix and matching for pistons etc so if you have specific questions about what the compression will be in your specific motor contact us directly.
I will start out with our very popular Piston/Rod Combos Starting from the least expensive. Make sure you ask us about package deals!
PISTON/ROD COMBOS
Wiseco Pistons/Eagle Rods Combo for H22
$799.99
(Comes with rings, locks, and pins. Rods come with ARP bolts)
Click HERE for compression ratios and bore sizes.
CP Pistons/Eagle Rods Combo for H22
$819.99
(Comes with rings, locks and pins. Rods come with ARP bolts)
JE Pistons/Eagle Rods Combo for H22
$824.99
Mahle Pistons/Eagle Rods Combo FOR STOCK SLEEVE H22
$879.99
Wiseco Pistons/Brian Crower H Beam Rods Combo for H22
$849.99
Wiseco Pistons/K1 H Beam Rods for H22
$849.99
CP Pistons/Brian Crower H Beam Rods for H22
$875.00
Click HERE for bore sizes and compression ratios.
CP Pistons/K1 H Beam Rods Combo for H22
$895.00
(Comes with rings, pins, and locks. Rods come with ARP bolts)
JE pistons/Brian Crower H beam rods Combo
$899.95
CP Pistons/Manley I beam Rods Combo
$1,189.99
JE Pistons/Manley I Beam Rods Combo for H22
$1,189.99
Wiseco Pistons/Pauter X Beam Rods for H22
$1,199.99
CP Pistons/Pauter X Beam Rods for H22
$1,219.99
JE Pistons/Pauter X Beam Rods for H22
$1,239.99
CP Pistons/Carrillo Pro-A Beam Lightweight Rods for H22
$1,250
(Comes with rings, pins, and locks. Rods come with WMC bolts)
JE Pistons/Carrillo Pro-A Beam Lightweight Rods for H22
$1,250
Wiseco Pistons/Carrillo Pro-H Beam Rods for H22
$1,639.99
(Comes with rings, pins, and locks. Rods come with CARR bolts)
CP Pistons Carrillo Pro-H Beam Rods for H22
$1,689.99
(Comes with rings, locks, and pins. Rods come with CARR bolts)
JE Pistons/Carrillo Pro-H Beam Rods for H22
$1,714.99
PISTONS
Wiseco Forged 2618 Pistons for SLEEVED H22
$499.99
(Comes with rings, pins, and locks.)
Mahle PowerPak Forged 4032 Pistons for SLEEVED H22
$569.99
(Comes with rings, pins, and locks)
JE Forged 2618 Pistons for SLEEVED H22
$549.99
Mahle Gold Series Pistons for STOCK SLEEVE H22
$575.00
CP Forged 2618 Pistons for SLEEVED H22
$592.20
CONNECTING RODS
Eagle H Beam Rods for H22
$329.99
Comes with ARP bolts
$359.99
K1 4340 H Beam Rods for H22
$399.00
Manley I-Beam 1000hp Rods for H22
$739.99
$750.00
Comes with WMC bolts
Pauter X Beam 1000hp Rods for H22
$775.00
Carrillo Pro-H Beam 1100hp Rods for H22
$1,199.99
Comes with CARR bolts
BLOCK GUARDS
Supertech Block Guard for H22
$99.99
HEAD/MAIN STUD KITS
ARP Headstuds for H22
$149.99
ARP Mainstuds for H22
$106.95
BEARING KITS
Clevite Bearing kit for H22
$119.99
ACL Race Bearing kit for H22
$139.99
HEADGASKET
Cometic Headgasket for H22
$99.99
BLOCK GUARD
$99.99
SLEEVES
Darton MID Wet Sleeves for H22
$587.00
MOUNT KITS
Avid H-Series Motor Mounts Kit for EG Civic/DC Integra
$289.98
Avid H-Series Motor Mount kit for EK Civic
$339.98
CAMSHAFTS
Brian Crower Stage 2 Turbo Cams for H22
$439.38
Brian Crower Stage 2 All Motor Cams for H22
$439.38
Brian Crower Stage 3 All Motor Cams for H22
$439.38
Skunk2 Tuner Stage 1 Cams for H22
$633.99
Skunk2 Tuner Stage 2 Cams for H22
$655.99
Skunk2 Pro Stage 1 Cams for H22
$655.99
Skunk2 Pro Stage 2 Cams for H22
$688.99
Skunk2 Pro Stage 3 Cams for H22
$719.99
Kelford Stage 1 Turbo Fast Street Cam for H22
$607.50
Kelford Stage 1 All Motor Street Cam for H22
$607.50
Kelford Stage 2 Turbo Race Cam for H22
$607.50
Kelford Stage 2 All Motor Ultimate Street Cam for H22
$607.50
Kelford Stage 3 All Motor Street/Strip Cam for H22
$607.50
Kelford Stage 4 All Motor Drag Race Cam for H22
$607.50
VALVESPRINGS AND RETAINERS
Supertech Dual Valvesprings & Retainers for H22
$329.99
Brian Crower Dual Valvesprings and Retainers for H22
$346.88
Skunk2 Tuner Dual Valvesprings and Ti Retainers + Base kit for H22
$444.97
Ferrea Beehive Valvesprings & Ti Retainers for H22
$529.99
Skunk2 Pro Dual Valvesprings and Ti Retainers + Base kit for H22
$551.97
Ferrea Dual Valvesprings and Ti Retainers for H22
$579.99
VALVES
Ferrea 5000 Series Valves for H22
$199.99
Ferrea 6000 Series Valves for H22
$249.99
Supertech SS Valves Black Nitrided for H22
$269.99
Brian Crower SS Valves for H22
$286.76
Skunk2 Pro Series Valves for H22
$291.99
Ferrea Competition Plus Valves for H22
$358.20
CAM GEARS
AEM Tru-Time Adjustable Cam Gears for H22
$199.80
Skunk2 Pro Series Adjustable Cam Gears for H22
$244.99
VALVE GUIDES
Ferrea Bronze Valve Guides for H22
$84.99
Supertech Bronze Valve Guides for H22
$89.99
VALVE SEALS
Supertech Valve Seals
$19.99
Ferrea Valve Seals for H22
$24.99
INTAKE MANIFOLDS
Skunk2 Pro Series Intake Manifold for H22
$364.99
THROTTLE BODIES
Blox Billet Throttle Body for H22
$249.99
Skunk2 Pro Series Throttle Body for H22
$297.99
Skunk2 Black Series Throttle Body for H22
$309.99
Old Mar 16, 2011 | 06:23 AM
RealStreet's Avatar
Default Re: H22 Build thread!!! MASTER PRICE SHEET!!! UNBELIEVABLE PACKAGE DEALS!!!
To the top!
Old Mar 17, 2011 | 07:18 AM
RealStreet's Avatar
To the top!
Old Mar 18, 2011 | 05:51 AM
RealStreet's Avatar
All pm's replied to!
Old Mar 22, 2011 | 06:27 AM
RealStreet's Avatar
All PM's replied!
Old Mar 24, 2011 | 05:17 AM
RealStreet's Avatar
Thanks for the support! PM's replied!
Old Mar 24, 2011 | 05:26 AM
JDM_COUPE's Avatar
looks like you guys are my new best friends lol.. sent pm
Old Mar 25, 2011 | 01:02 PM
RealStreet's Avatar
haha, thanks!!!
Old Mar 28, 2011 | 05:14 AM
RealStreet's Avatar
to the top
Old Mar 29, 2011 | 05:12 AM
RealStreet's Avatar
Fat Tuesday bump
Old Mar 30, 2011 | 06:58 AM
RealStreet's Avatar
To the top
Old Mar 31, 2011 | 02:30 PM
RealStreet's Avatar
End of the month bump!
Old Apr 4, 2011 | 05:35 AM
RealStreet's Avatar
PM's replied
Old Apr 5, 2011 | 06:25 AM
RealStreet's Avatar
To the top
Old Apr 6, 2011 | 10:50 AM
RealStreet's Avatar
The the top
Old Apr 11, 2011 | 06:02 AM
RealStreet's Avatar
To the top!
Old Apr 12, 2011 | 05:21 AM
RealStreet's Avatar
PM's returned
Old Apr 13, 2011 | 05:56 AM
RealStreet's Avatar
To the top!
Old Apr 14, 2011 | 11:10 AM
RealStreet's Avatar
All pm's returned
Old Apr 15, 2011 | 05:22 AM
RealStreet's Avatar
Thanks for the pm's!
Old Apr 18, 2011 | 07:35 AM
RealStreet's Avatar
Monday bump!
Old Apr 19, 2011 | 07:18 AM
RealStreet's Avatar
To the top!
Old Apr 20, 2011 | 06:03 AM
RealStreet's Avatar
To the top!
Old Apr 21, 2011 | 05:57 AM
RealStreet's Avatar
bump!
Old Apr 22, 2011 | 05:31 AM
RealStreet's Avatar
It's Friday!
