94 Honda prelude Vtec door lock/unlock wires
Hello!!! I'd like to get some help from you guys. I'm installing an alarm for my car and I can't locate the door lock/unlock wires in the passenger kick panel.
Any ideas how should I wire it? I tried googling, did not help much. thanks in advance!
Here's a pdf print out from Directechs for the 94 Prelude. It has a note under the door lock and unlock sections listing more about where the plug is located (behind black foam)
The link is good for 30 days, or 30 days after the last download (or something like that.. I forget how FileDropper works)
http://www.filedropper.com/94prelude
It also says you can get it at the factory security plug located to the left of the steering column
Thanks for the reply 1GPlusSH & rjr162. I did checked both locations (Passenger's Kick 10 Pin Connector or at OEM Alarm & Connector left of Steering Column) prior to posting here. I did not find the Black/White (-) in the passenger kick panel. I even removed the whole panel check all connecto and did not find a 10 pin connector that has black/white (-) or Black/red (-). Same goes in the Steering column (did not find those wires). I'm pretty sure nothing on the kick panel, I may have overlooked in the steering column. If I don't find it in the sterring column, how should I go about? thanks again.
I'm thinking of just wiring it from both of the side door, would that be ok?
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
slow motion
Aug 17, 2004 12:57 AM
