z6 vs b8 head dimensions
Old Mar 15, 2011 | 03:02 AM
Rydin's Avatar
Default z6 vs b8 head dimensions
Ok, I bought a new ac ramhorn/downpipe for a d16z6. I was mocking it up on a spare z6 block with a b8 head. The problem is the downpipe is hitting where the oil pan mates to the block. I shaved the block to get an idea how off it was. I'd say it's about a 1/4" - 2/5" off. Now my question is. Does the casting(Correct term? idk) on a vtec head go out further than a usdm d15? Or are they pretty much identical?
To the right is the ac bracket and compressor.
Old Mar 17, 2011 | 07:34 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: z6 vs b8 head dimensions
I was just looking at some old pics and it doesn't appear to be any different. Look specifically at the middle front where the machining tab is at (small circle in front of the middle/front head bolt hole):
B8
Z6
Y8 for reference but should be the same:
If you really need it, I can take measurements off of some spare heads I have laying around.
Beasty91Hatchy
Oct 28, 2010 01:51 AM
therealzk
Sep 18, 2007 09:51 AM
Change
Aug 29, 2004 07:31 PM
turbo sol
Aug 28, 2002 03:15 PM
