How to test the Main relay?
Old Mar 14, 2011 | 07:20 PM
shahriar35's Avatar
Default How to test the Main relay?
Hey all, car is not starting up. I want to know how to check if the main rely is still good? It might be a newbie question but Im a newbie w/ electrical. Thanks in advance
Shah
Old Mar 14, 2011 | 07:51 PM
Kris's Avatar
Default Re: How to test the Main relay?
Listen for two clicks when you put the key in the number two position, one when the check engine light comes on and one when the check engine light goes off. If you dont hear it click try tapping on it while putting the car in the number 2 position.
Old Mar 15, 2011 | 07:20 AM
Tyrant_007's Avatar
Do you have a factory service manual? Here's how to test your pump using the main relay.
Not 100% sure whether or not it confirms the main relay is bad or not though.
Found this though: http://www.tegger.com/hondafaq/mainr...ing/index.html
Old Mar 15, 2011 | 12:02 PM
mafi83's Avatar
Are you getting any type of cranking/starting noise? Does the panel light up? Check the grounds and battery first. Best of luck!
Grey_accord
Apr 11, 2014 03:31 AM
fenix4o9
Mar 26, 2010 05:41 PM
4gen5thtime
Apr 22, 2009 03:46 PM
luckygispol1
Sep 10, 2005 03:32 PM
