ebay camber kit, is it ok to use?
Old Mar 14, 2011 | 04:30 PM
dtran002's Avatar
Default ebay camber kit, is it ok to use?
I am looking to get these kind of camber kit, but it from ebay, so I don't know if it worth the try. Here are the two links I am thinking of, one is just for the front, the second is for front and back.
http://cgi.ebay.com/ebaymotors/BLUE-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/90-97...Q5fAccessories
what do you guys think?
Thanks
Old Mar 14, 2011 | 04:38 PM
HONDA1luv's Avatar
Default Re: ebay camber kit, is it ok to use?
the adjustable control arms in the second link are good, i got some of those. but for my front i got adjuatable ball joints.
looks like this http://www.clubrsx.com/cr/SPC-67135-...mpaign=froogle
Old Mar 14, 2011 | 04:41 PM
dtran002's Avatar
yeah, I did look into those ball joints one, but for sure its will not last long on my car since the frame and the control arm banging each other often on my car lol. I guess I'll get the ebay one, hope it will last. Thanks for the input
Old Mar 14, 2011 | 04:47 PM
ian1006's Avatar
Dont buy ebay junk. The rubber in the bushings is terrible, I know I had ebay camber kit for my civic and they fell apart. There is a reason it is so cheap.
Old Mar 14, 2011 | 05:00 PM
wolfy47's Avatar
^^^That
also adding a camber kit will only make the banging worse since it takes away clearance
Old Mar 14, 2011 | 05:11 PM
dtran002's Avatar
Yes, adding the camber will make the banging worst, but I'll try to grind down a bit on the control arm and see if it help any. Banging noises are still better than replacing tires once every couple of months lol. I'll look around for some more
Old Mar 14, 2011 | 05:18 PM
wolfy47's Avatar
have you gotten a alignement? if so do you get custom settings all around??
if you dont, set the toe to zero all around and skip the camber kit all together
Old Mar 14, 2011 | 05:57 PM
dtran002's Avatar
I did, toe is nearly 0, its in the tolerance range, but the camber, left front is -1.5 degree, the right front is -2.3degree off.
Old Mar 14, 2011 | 08:24 PM
HONDA1luv's Avatar
how low is your car?
Old Mar 15, 2011 | 04:00 PM
dtran002's Avatar
Running on 215/45/17, I don't know how low it is but it only fit one finger, the pinkie one lol...To be exact, my camber wasn't so bad the past three years until I just changed the upper control arm, that's when my camber go crazy.
PsXtreme
May 1, 2017 10:09 PM
400whp
Mar 26, 2016 12:52 PM
averyvm
Suspension & Brakes
15
Sep 11, 2009 05:52 PM
honda95civic
Sep 21, 2005 07:30 PM
evo
Apr 12, 2003 11:49 AM
