Suspension & Brakes Theory, alignment, spring rates....
Koni/GC Spring Rates
Old Mar 14, 2011 | 04:05 PM
zeroartgfx's Avatar
Default Koni/GC Spring Rates
Ok so i know this has been asked before but i just want to confirm before ordering. I have a 98' Civic hatch with 205/50 tires 15x6 GSR wheels, i dont mind a stiff ride, but i dont want to kill my back either after 15 min of driving lol. Id also like to drop it like 3 inches or so, maybe lower this summer. I called up GC and they said that they wont help me until i order them, but im not ordering from them, ahah. I then called THMotorsports and asked them, they said the "usual" 380/450.
So my question is: Who here has the 380F/450R spring rate with koni/GC's and whats the ride quality like? Do you all who own GC/koni's agree with this spring rate?
PS: I plan on getting GC top hats later
Old Mar 14, 2011 | 05:01 PM
batallic's Avatar
Default Re: Koni/GC Spring Rates
those seem alright, but i would put the 450 in the front 380 rear, why not just get the top hats all at once, while your at it
Old Mar 14, 2011 | 05:18 PM
zeroartgfx's Avatar
money ahah. and why switch the spring rates? what do you run?
Old Mar 14, 2011 | 06:04 PM
98civdx's Avatar
Master Detailer
400F/450R Or 450F 400R is what I would do.
The rates they said, will work though.
No need for all 4 top hats, I would recomened getting fronts though.
Old Mar 16, 2011 | 08:09 AM
VTECIntegra9's Avatar
Those rates will be fine for your street car - put the softer springs in the rear for better ride comfort... Swap them to reduce understeer (but will soften up the front)
Old Mar 16, 2011 | 08:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had 380 lb 8" front springs and 450 lb. 7" rear springs. Ride quality was AWFUL! I was commuting 100 miles a day at that time and I ended up selling them after only 10 months. I was decently lowered (not slammed, see pic below) with OEM top hats and had no problems at all.
If I had to do it again I'd go with 400 lb. 8" front springs and 300 or even 250 lb. 7" rear springs. Although you should get the same spring length if you ever intend to swap them back to front.
So 400/250 is my vote for decent ride quality. I would do that along with the ITR rear sway bar so you don't need a super stiff ride-killing rear spring to help control the rear of the car.
Old Mar 16, 2011 | 10:35 AM
98civdx's Avatar
Master Detailer
He said he wants to go 3"+
Only reason I said gets rates that high.
Patrick, do think 300lb is enought for a 3" drop?
Old Mar 16, 2011 | 10:40 AM
zeroartgfx's Avatar
yeap you are correct, i want 3+ drop. So is 300lb enough for rear?
BTW: ordered top hats for the front.
Old Mar 16, 2011 | 11:02 AM
Community Builder
For the rear? Definitely. There is no huge upper A-arm in the rear to hit anything like there is up front.
Old Mar 16, 2011 | 11:08 AM
zeroartgfx's Avatar
aight good to know. and what about my tires. you think there too big to go that low?
Old Mar 16, 2011 | 11:15 AM
Community Builder
Shouldn't be a problem - 205/50-15 is slightly smaller in diameter than my 205/45-16's you see pictured above. However I perfer 195/50-15 for OEM 15" wheels. Yeah it's smaller than stock blah blah but I like it better.
Old Mar 16, 2011 | 11:45 AM
zeroartgfx's Avatar
gotcha. i do plan on getting new tires soon so ill probably go with 195/50-15's then. Hey what kind of rear sway bar would you recommend? I see that eibach has a rear sway bar with all the parts included for like 180$, think i should go with that? Thanks again for the help.
Old Mar 16, 2011 | 12:03 PM
98civdx's Avatar
Master Detailer
Do you have a front bar?
Old Mar 16, 2011 | 05:19 PM
zeroartgfx's Avatar
i dont believe so. did the 98 dx come with one? id have to check tom.
Old Mar 16, 2011 | 06:19 PM
98civdx's Avatar
Master Detailer
No, they did not.
Old Mar 16, 2011 | 09:59 PM
98civdx's Avatar
Master Detailer
Originally Posted by abs0Lut
OEM ITR, adjustable end links, ITR LCA's.
He would than need a subframe brace. Washers for the sway bar. Not to mention, the only "ITR" LCA that will work is F7, and they are $300+. Oh Yea, he'll also need ITR type shocks too.
Also, without a front sway bar, a 22mm in the rear may create a lot of over steer. Something he may not be looking for.
Ef4doorwagon
Dec 16, 2015 12:54 PM
yoitspbj
Suspension & Brakes
25
Apr 1, 2013 09:05 AM
Corruption
May 18, 2005 10:57 AM
internet ay
14
Apr 4, 2002 08:44 PM
