D15B8 harmonic balancer special tool to install: where do I get one?
Old Mar 14, 2011 | 03:55 PM
r.etheridge's Avatar
Default D15B8 harmonic balancer special tool to install: where do I get one?
Im installing a crank pulley/ harmonic balancer on a D15B8 cx motor and need the special tool so that I can get it TQ'ed to 145 Ftlbs. The pulley has 8 holes around it. Where can I get the special tool? herea a link to the harmonic balancer. http://www.partsgeek.com/catalog/199...ft_pulley.html
part #W0133-1609466
second one from the top. Thanks for any help
Old Mar 15, 2011 | 01:40 AM
Default Re: D15B8 harmonic balancer special tool to install: where do I get one?
anybody?
Old Mar 15, 2011 | 01:52 AM
suthernbred904's Avatar
i just used an allen wrench or screw driver to block/hold it in place on my b18c1 when i was changing over itr cams. just an idea...i heard u can get the tool at sears though...
Old Mar 15, 2011 | 03:21 AM
BryanM.'s Avatar
Resident Gearhead
>>> http://motors.shop.ebay.com/__?_from..._id=1259305611 <<<<
Old Mar 15, 2011 | 05:02 AM
ill check sears, I need one different than the typical hex shaped holder because inside the pulley its round. I tried a big craftsman screwdriver but it bent it. The TQ is 145ftlbs. I have one of the new style crank bolts with a 10 printed on the end
Originally Posted by mcvtec
WRONG..... look at the link I have posted for the pulley, the center of it is round, not hex shaped
Old Mar 15, 2011 | 07:51 AM
vtechjunkie's Avatar
Just use an impact wrench.
Old Mar 15, 2011 | 09:01 AM
24TEN's Avatar
PHANTOM MENACE
You might be able to get away with leaving the car in gear and having a friend press the brakes while you torque (or remove) the bolt. Of course this is assuming the engine is in the car.
Old Mar 15, 2011 | 09:29 AM
Rylan's Avatar
How is pushing the brakes going to stop the harmonic balancer from turning? lol
Old Mar 15, 2011 | 09:34 AM
the engine is out.
Old Mar 15, 2011 | 09:35 AM
he said hold the brakes im assuming because if the car were to come out of gear the car would roll foward and over you if you were applying that much TQ
Old Mar 15, 2011 | 09:40 AM
Rylan's Avatar
Ohhhh okay haha makes sense.
Can you not use an impact gun with a torque stick for the correct about of torque needed?
Old Mar 15, 2011 | 09:56 AM
BryanM.'s Avatar
Resident Gearhead
Sorry, no need to yell at me.
standy xsi
Dec 2, 2011 04:14 AM
turboedsupe
Sep 1, 2008 11:20 AM
duffman1278
Jul 19, 2008 07:57 PM
yz125rider21
13
Dec 14, 2005 07:23 PM
94vtecmn
Apr 21, 2003 12:08 PM
