turbo inlet intake velocity stack? yah or nah
how much benifit will u get from running a filter off the turbo verse intake piping away and then to plum a pipe with filter...
would/could a turbo benfit from a velocity stack?
any pics of setups and any dyno results?
I know by putting an intake to the turbo will cause a loss of power theres some threads around with dyno'd results and I think by adding the veloscity stack you will gain some horse power
You dont want your car sucking in hot air from the radiator or debris that may be hitting the front of the car... this is my setup although i should have some kind of aluminum shroud blocking radiator heat from the filter would improve the design more...
the 4" intake/velocity stack lowered intake temperatures and improved horsepower on the dyno verse the heat from the radiator going straight into my turbo lol
im running same turbo.. but my setup in pointing it the driver side..
Who is Mr Robot?
run an intake out of the engine bay with a real filter.... your motor and turbo will thank you
slayer423
Dec 18, 2012 02:13 PM
slayer423
Dec 15, 2012 06:29 PM
ke98248
Nov 29, 2007 07:38 PM
