Liter size of a 79mm bore D16?
Old Sep 26, 2002 | 04:46 PM
*Boostwerks*'s Avatar
Default Liter size of a 79mm bore D16?
what would be the Liter size of a D series motor with a 79mm bore?
thanks for any info
Old Sep 26, 2002 | 04:48 PM
Sonny's Avatar
Default Re: Liter size of a 79mm bore D16? (Bryson)
1764.549cc
1.764549 liters
Got sleeves?
Sonny
[Modified by Sonny, 5:48 PM 9/26/2002]
Old Sep 26, 2002 | 04:52 PM
Default Re: Liter size of a 79mm bore D16? (Sonny)
1764.549cc
1.764549 liters
Got sleeves?
Sonny
hahahah......
GE + custom Endyn
Old Sep 26, 2002 | 06:33 PM
mntdewred's Avatar
79mm? and you want to boost? good luck
[Modified by mntdewred, 10:33 PM 9/26/2002]
Old Sep 26, 2002 | 07:02 PM
TURBOSALES's Avatar
Default Re: Liter size of a 79mm bore D16? (mntdewred)
heres the equation for future reference.
bore x bore x stroke x 3.1416 = displacement
then move the decimal.
HTH
Old Sep 26, 2002 | 08:41 PM
Sonny's Avatar
Don't forget that as bore size increases and piston dome displacement stays the same, your compression ratio will increase. You won't have to mill off as much as you think if the stock chamber size is kept and the piston dome is not expanded.
mtndewred: Anything is possible with a sleeved block.
turbosales: It's actually (bore/2) * (bore/2) * (stroke) * 3.1415. If you don't half the bore, you are using the diameter of the bore and not the radius. Area of a cylinder = pi * (radius) ^2 * height
Sonny
[Modified by Sonny, 9:42 PM 9/26/2002]
Old Sep 26, 2002 | 09:03 PM
TURBOSALES's Avatar
im sorry, but the equation is
bore x bore x stroke x pi (around 3.1416) for a 4 cyl motor and you would divide by 4 to find the volume per cyl.
when i work your equation out, its not coming thru...
by the way, i know there is tons of different ways to find this out, i just feel this is the easiest. i know people that use pi/2 in their calculations.?.?
lol new post, different ways of figuring engine displacement.
[Modified by TURBOSALES, 6:05 AM 9/27/2002]
[Modified by TURBOSALES, 6:06 AM 9/27/2002]
Old Sep 26, 2002 | 09:18 PM
Sonny's Avatar
Default Re: Liter size of a 79mm bore D16? (TURBOSALES)
Yeah, there are tons of ways. Arturbo has some ultra simple one. I think our calculations are working out different because mine does it in cm and yours does it in mm. Mine gives volume per cylinder and yours gives it for the entire engine.
Ie, 79mm bore and 90mm stroke = 7.9cm bore and 9.0cm stroke per cylinder
(7.9/2)^2 * 9.0 * 3.1415 = 441.137cc per cylinder
4 cylinders = 1764.549cc
Whatever floats your boat, I guess. Yours is simpler though.
Sonny
Old Sep 26, 2002 | 09:27 PM
inspyral's Avatar
What's the max you could sleeve a D block to if you were building it for boost?
Old Sep 30, 2002 | 09:47 AM
So how much do you think the CR would increase with a 79mm bore?
Assuming I'm going with a 8.5:1 piston.
Old Sep 30, 2002 | 10:19 AM
Sonny's Avatar
If you have a 75.5 mm bore and the dome/dish volume of the piston is ~-5cc (about the what the ZC rollerwave piston is), your compression ratio is ~8.42:1 with the stock headgasket (.048").
If you go to 79mm with the same dome/dish, the compression ratio jumps to 9.05:1. You need to find out if the dome/dish configuration is changed when the piston is custom made to be that big.
Sonny
Old Sep 30, 2002 | 10:23 AM
Yeah....I'm going to email Endyn in a few hours and see what they say.
That would be perfect if it will increase compression a full .5:1.
Now would shaving the head be any different now?.....Like the .02" would result in a 1/2 pt of CR increase with a stock bore, but would that concept stay the same if the bore has been enlargened?
Old Sep 30, 2002 | 12:10 PM
VTC_CiViC's Avatar
I hope you're not boosting with those 79mm sleeves! GE reccomended a MAX with their 'zilla sleeves of 78mm for boost which is why I played it safe with 77mm myself. 79mm just doesn't leave you enough meat to boost on!
Old Sep 30, 2002 | 12:49 PM
Default Re: Liter size of a 79mm bore D16? (VTC_slow_CiViC)
really?
hmmm.....
I guess I'm going with 77 then....
Turbocivic94
Jun 8, 2004 04:36 PM
rOby
Jul 15, 2002 10:16 PM
uNF$@#!
Jul 9, 2002 05:06 AM
