Removing sunroof panel question
Old Mar 13, 2011 | 08:32 PM
96Formula6spd's Avatar
Default Removing sunroof panel question
Hey guys quick question. My sunroof has some broken supports. Anyways I picked up a good one out of the junkyard right before the car got crushed for $33. Anyways the new panel is rusted out but has a good set of tracks and the pieces and mount to the track. I was wondering if you could remove the panel with out having to take the head liner out. Thanks in advance.
Old Mar 14, 2011 | 03:57 AM
BiGZ's Avatar
Default Re: Removing sunroof panel question
Look in the FAQ stickied @ the top of this forum,seriously???
Old Mar 14, 2011 | 09:31 AM
ThatRicerDaniel's Avatar
Take the headliner out. I dont understand why you wouldent want to just drop the headliner. It is easy.
Old Mar 14, 2011 | 08:17 PM
Yeah I was able to get the panel out with the headliner still in. Got to pull it anyways since the track it broke on one side.
Old Mar 14, 2011 | 08:27 PM
faster Type R's Avatar
I'm planning on replacing just the glass of the moon roof. Since you have some experience with it do you know if you can uninstall just the glass piece without taking out the headliner?
Old Mar 14, 2011 | 08:40 PM
You can on the metal one in a crx. Open the sunroof. Look under the glass on the back support and there is a 8mm nut to take the back plastic stopper off. Remove them on both sides. Then remove the 10mm bolts at the front of the panel. Slide it forward and remove it.
Old Mar 14, 2011 | 08:56 PM
What about the glass one in a Civic?
Old Mar 14, 2011 | 09:01 PM
Should be the same. Not saying it is but honda usually does the same thing for 30 years.
Old Mar 15, 2011 | 01:02 AM
Sounds good thanks! I'm gonna check it out this weekend.
oprac
Aug 17, 2007 10:32 AM
fathergoose
Sep 24, 2006 06:22 AM
cs_x21
May 9, 2004 05:22 PM
nsxmugen
Jun 1, 2003 06:43 PM
Sivik
Mar 18, 2003 08:19 AM
