no spark 93 GSR!
so im helping my buddy with his 93 gsr teg . no spark . getting power to the distributor. swapped the distributor from a running a 94 gsr teg . still no spark. i swapped the ecu also and still no luck. the distributor splines only goes in one way so idk what to check for now. anyone got any experience like this?
Check your grounds. Try another dizzy just to make sure. I had the same problem by buying a used dizzy off a running car and it didn't work after I was installed. The coil went out.
in the diagram it doesn't show that it controls or has part to do in the ignition system. i tried a different main relay from a running car.. can i use the P06 ecu to see if the ecu is good? for temporary use
Annihilata
Jan 9, 2019 04:04 PM
-Hooper-
Jun 8, 2009 08:42 AM
93_hatchback
Feb 27, 2009 11:30 AM
chicows18
21
Jan 16, 2008 09:30 AM
d_a_b
Oct 11, 2006 09:14 PM
