Da9 suspension help
Old Mar 13, 2011 | 05:46 PM
DAnine-er's Avatar
Default Da9 suspension help
II wanted to know if skunk 2 front upper control arm ball joints fit in ebay upper control arms camber kit
Old Mar 13, 2011 | 06:09 PM
91_LS's Avatar
Default Re: Da9 suspension help
So you want to know if the Skunk adjustable ball joints (CAMBER KITS) will fit the Ebay camber kits.??
Why would you want to install a camber kit on a camber kit?
Old Mar 13, 2011 | 07:30 PM
DAnine-er's Avatar
Ok I dont know if I asked the? Wrong but I want to get skunk 2 ball joints on ebay upper control camber kits.
That means remove the original ball joint the ebay kit comes with and replace it with skunk 2 ball joints, you get what I mean?
Old Mar 13, 2011 | 07:43 PM
91_LS's Avatar
No it wont work.
The skunk ball joint is made to work with the stock control arm and slide on its own mount seen here http://cgi.ebay.com/ebaymotors/SPECI...0608448084,the Not the skunk but looks just like it.
Ebay control arm kits are set up to slide on its own control arm as seen here http://cgi.ebay.com/ebaymotors/90-91...Q5fAccessories.
Old Mar 13, 2011 | 07:49 PM
91_LS's Avatar
Now if this is what you're looking to get,it still wont work.
http://cgi.ebay.com/ebaymotors/SKUNK...item3365649380
thumper64
Nov 8, 2009 02:46 PM
russianswty
Mar 9, 2007 10:26 PM
slipstream
Aug 16, 2005 01:56 AM
turbotime
Apr 14, 2005 09:00 AM
