Downside to removing P/S pump?
Old Mar 13, 2011 | 11:12 AM
mem94043's Avatar
Default Downside to removing P/S pump?
I am changing my first T-belt and wpump on a 95 Accord LX. Is there a downside to removing the power steering pump? I would love to get that sucker outta the way. Does it need to be bled after re-install? Can that even be done on this car?
My preference would be to disconnect it at point #1, and if not, at point #2 (see pic) in order to move it farther out of the way. Any feedback Accord gurus?
Thanks!
Mike
Old Mar 13, 2011 | 11:52 AM
94EG8's Avatar
Seagull Management
Default Re: Downside to removing P/S pump?
Downside is you'll make a bit of a mess and have to buy some honda P/S fluid (which is somewhat pricey, do not use ATF or regular P/S fluid unless you feel like replacing the pump and rack) It has to be bleed, but the bleeding procedure is simply turning the wheel lock to lock of a few times.
Personally I just swing the pump up out of the way and tie it up with something rather than disconnecting the lines.
Old Mar 13, 2011 | 01:37 PM
accordmatt's Avatar
^ yup disconnecting the lines u will have to bleed but is very easy.
Old Mar 13, 2011 | 02:04 PM
malakilla's Avatar
There is plenty of room to do your task without removing the pump 100%. Just unbolt it, and pull it and the resivour bottle out of the way.
Old Mar 13, 2011 | 06:59 PM
mem94043's Avatar
Originally Posted by malakilla
There is plenty of room to do your task without removing the pump 100%. Just unbolt it, and pull it and the reservoir bottle out of the way.
It actually moves out of the way very little so I pulled it. Just took my brake bleed kit and sucked all the fluid out of the reservoir and attached hose. Hardly made a mess at all. Now I can move the one hose towards the firewall and take the pump, other hose, and rez completely out.
Old Mar 13, 2011 | 07:16 PM
MAD_MIKE's Avatar
MM Gruppe B
I'm with malakilla the PS pump is easy to move out of the way, IIRC there is a hose bracket on the firewall side where the PS hose goes down to the rack. 10mm I think. Remove that bolr/bracket and the hose allows you to flip the PS pump up and out of the way.
free_money
Jun 26, 2014 07:41 PM
crx-b18c
Mar 31, 2010 05:09 AM
Prudz_lude
Jun 9, 2007 01:20 PM
deftyes
Nov 13, 2006 04:10 PM
earthworm
Jun 2, 2005 08:37 PM
