91 civic base craps out when throttle applied
Old Mar 13, 2011 | 10:38 AM
cricketracer's Avatar
Default 91 civic base craps out when throttle applied
I have a 91 civic base, dual point injection that runs well at idle and with light throttle. But at maybe 1/4 to 1/3 throttle application it begins to crap out. It is OBD1 and is not throwing any codes. The top fuel injector is spraying fuel and if I disconnect the lower injector at idle the engine dies. Fuel pressure is good. Plugs are good, and I've even checked compression; 155 - 160 all cylinders.
The car was running fine and just started this a vew days ago. Any ideas?
Old Mar 13, 2011 | 07:41 PM
HAfinatic's Avatar
Default Re: 91 civic base craps out when throttle applied
i would check the resistance of the bottom injector and make sure it still has proper current for the wiring. give that a shot. youll need a dmm.
Old Mar 13, 2011 | 09:21 PM
~sp33~'s Avatar
EFB055
OBD1 and still DPFI? Interesting.
Line the engine up and check everything is still at TDC?
max323
10
Aug 25, 2011 06:07 PM
pzany89
Feb 4, 2011 11:26 AM
betojr82
Jul 22, 2010 05:43 AM
squeaky
Jul 30, 2004 07:47 PM
ryanplayjoint
Jul 15, 2004 08:54 PM
