<<Can you drop a obd1 block in EF>>
Old Mar 13, 2011 | 09:11 AM
94mugenteg's Avatar
Default <<Can you drop a obd1 block in EF>>
Can you drop a obd1 block in EF with the same obd0 wire harness if you switch all sensors???
because my car is smoking white smoke...i have 95 non vtec head with stock HF mani with a D15B block ?
what do you guys think
should i just fix what ever it is or change the block to a 95 obd1 that i have laying around ?
Old Mar 13, 2011 | 10:17 AM
k20rex's Avatar
Default Re: <<Can you drop a obd1 block in EF>>
Will be no problem
Old Mar 13, 2011 | 11:13 AM
Deetz's Avatar
Crazy Honda Guy
OP, just so you know, it is not the block that carries an obd designation. On board diagnostics come from the distributor and ecu
boostedefhatch
27
Mar 8, 2009 02:27 PM
guymosiris
Feb 15, 2006 05:28 AM
MugenHonda
Dec 14, 2005 08:33 AM
Lsssleeper Coupe
Mar 15, 2005 08:10 AM
