Help:trans won't go into gear at high rpm's
I have a gsr trans jus put a brand new CC stage 5 in it
Took it to the track an for some reason it wont go in to gear at high rpm's....I need some help I was told it was the pressure plate not being able to hold the 490hp an 380tq....please help me
I had same problem with my stage 5. I have a good feeling its just due to the clutch not fully disengaging. You need to lay on your back under the steering column and adjust the clutch pedal. Its a 12mm nut on the rod that goes into the clutch master cylinder. Asjust it so the clutch engages with the pedal out further thus being able to push the clutch in further and fully disengaging it.
No mine handles the same torque no problem. I have the upgraded plate though. The clutch not holding the torque wouldn't really be a reason for it not to go into gear. Adjust that pedal and give it another shot
No always true. Why do CC stage 5 with upgraded pressure plates(2300lb) hold more than ACT 2900lb clutches? Pressure is relative but the fulcrum(sp) point is what makes the clutch hold the power
the act is a 6 puck i do believe. the cc is 4 puck. so the 4 puck has more pressure on those 4 pucks. the 6 puck is spread out a little more to the otehr 2 pucks this making each puck having less pressure on each.
i think i might have figured the problem out......how many bolts does the pressure plate have?... cause i think like 2 of them are missing.
Ive used a stock throwout bearing on the clutch with no problems. Same with my CC twin disc
ive had shift forks do both things. ive had a trans grind like a SOB low rpms but go in fine at 8k and ive had a trans shift like butter at low rpms and would not go in above 7k.
and never once said it was all 3 forks.
both were to to shift forks with chunks broken off of them. and after they were replaced the trans shifted like butter no matter the rpms
youve obv never had this happen before.
well he didnt say anything about any gear directly. and also you are right about if the trans was alright before swap.
i guess this just mean more info is needed. unless the 2 bolts that are missing on the pp are his problem
yeh its always good to put all the bolts in lol
