fuse 14 under dash blowing causing no spark or fuel
Old Mar 13, 2011 | 01:28 AM
N'viouzEF9's Avatar
Default fuse 14 under dash blowing causing no spark or fuel
ok so i had fixed my car and it worked perfect and once again my car died while i was driving and i checked the fuses and its the number 14 it says for the alternator so i changed it and it worked fine again so what can it be thats making it blow its a obd1 ef could it be that i had broke the brown piece in the alternator that clips to the green plug n i changed it for a obd1 ls one i had it like that b4 n never had a problem? anybody know?
Old Mar 14, 2011 | 01:31 AM
HAfinatic's Avatar
Default Re: fuse 14 under dash blowing causing no spark or fuel
did you convert your whole wiring to obd1? if the plug on the alternator is broken it could be shorting out there and blowing the fuse every time it does. just a thought.
Old Mar 14, 2011 | 06:13 PM
N'viouzEF9's Avatar
the plug used to be broken n i changed it for a ls one and im pretty sure all the harness is obd1 because i send it to rywire to be done
nxvictim
Feb 19, 2010 01:37 AM
teamworxek9
Sep 4, 2009 04:32 PM
boostedekhatch
Nov 9, 2008 08:52 PM
