OVERHEATING!!! Upper radiator hose is hot, but lower is cold!
Old Mar 12, 2011 | 09:23 PM
bradabu's Avatar
Default OVERHEATING!!! Upper radiator hose is hot, but lower is cold!
what up honda-tech. so i just replaced piston rings, head gasket etc and when i went to test drive it, everything was fine. but when i parked it, water was overflowing and boiling from the radiator reservoir. Im pretty sure its my thermostat, but some input would be appreciated. thanks.
*my upper radiator hose is hot and my lower is cold
Old Mar 12, 2011 | 09:36 PM
UnLuckyy's Avatar
Default Re: OVERHEATING!!! Upper radiator hose is hot, but lower is cold!
Thermostat for sure.
Old Mar 12, 2011 | 09:57 PM
Rylan's Avatar
Mines doing the same thing, I was told its probably the thermostat. Is your Fan engaging?
Old Mar 12, 2011 | 10:39 PM
eghatch9295's Avatar
Stancetard Hate Monger
thermostat.
Old Mar 12, 2011 | 10:48 PM
87 SiviK Si's Avatar
Originally Posted by Rylan
\probably the thermostat.
Originally Posted by eghatch9295
thermostat.
Old Mar 13, 2011 | 04:29 AM
dpetro1's Avatar
also make sure the system is bled properly. an air pocket could cause the thermostat not to open.
Old Mar 13, 2011 | 06:37 AM
JasonYo's Avatar
x2 had this problem
Do this first, if it doesn't work then change thermostat.
Old Mar 13, 2011 | 06:52 AM
Rylan's Avatar
You should also bleed it from the bleader on the upper rad hose close to the head.
Apparently its more affective that running your car with the rad cap off letting it bubble out.
Old Mar 14, 2011 | 11:21 AM
Rylan's Avatar
Bump, did you find the issue man?
Old Mar 14, 2011 | 02:42 PM
-__-'s Avatar
^^it was the thermostat lol. i knew it was the thermostat just from the symptoms. i took a look at the car personally. he changed it and its fine now. thanks guys.
93CamaroLT1
Jan 11, 2010 02:59 PM
IntegraR0064
Jan 27, 2009 10:41 AM
aj_scribble
Mar 20, 2008 10:28 AM
aziaticvang
Jan 31, 2008 06:41 PM
TypeR0186
Dec 3, 2004 09:16 PM
