Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Timing belt 2001 Honda Civic Ex VTEC
Old Mar 12, 2011 | 02:03 PM
zachz41's Avatar
Icon2 Timing belt 2001 Honda Civic Ex VTEC
I was wondering if anyone knows...does a 2001 civic ex have an automatic shutoff if the timing belt snaps, or would it ruin the valves / cause other damage if it breaks??
Old Mar 12, 2011 | 02:10 PM
toyomatt84's Avatar
Sanji
Default Re: Timing belt 2001 Honda Civic Ex V-tech
The D17 is a collision engine, so if your belt snapped... your valvetrain would be damaged.
Old Mar 12, 2011 | 02:11 PM
*JDM*Ej8*'s Avatar
Unless you get lucky like me and have no bent valves and throw a new belt on and ruin like a champ lol but thats not to likely. how fast were you going ect?
Old Mar 12, 2011 | 02:13 PM
zachz41's Avatar
im just concerned because i dont know if the previous owner ever changed it, considering it has 200,000 and the air filter had a mouse nest in it, im assuming the belt is pretty brittle by now
Old Mar 12, 2011 | 02:15 PM
zachz41's Avatar
any idea how much it would cost?
Old Mar 12, 2011 | 02:29 PM
toyomatt84's Avatar
Sanji
If you're doing the work yourself, $150 or so for the parts (I'd recommend doing the water pump at the same time, since they run on similar replacement schedules).
It Wasn't Me's Avatar
Default Re: Timing belt 2001 Honda Civic Ex VTEC
Do you plan on doing the work yourself? That will save you a fair amount of money. You should do the water pump, too. You're overdue. Also check the valve clearances (intake .18 - .22mm / exhaust .23 - .27mm), change the spark plugs, transmission fluid, brake fluid, cabin air filters, etc.
The kits (water pump, timing belt, tensioner, gaskets, etc) run around $150 - $190, depending on who you buy from and whether or not they're OEM parts. If you're going to have a shop do it, plan on spending well-over $400.
If you want to do it yourself, use this DIY from the FAQ's.
Timing Belt / Coolant Flush / Water Pump: Link
ajvb65
May 1, 2008 05:17 PM
rasta420
May 1, 2006 06:07 PM
paulsie1123
Oct 9, 2005 07:11 PM
