2001type sh swap into 93 si
Old Mar 12, 2011 | 02:13 AM
slowredsol's Avatar
Default 2001type sh swap into 93 si
I got a really good deal on a type sh full swap from a 2001. My question is, is there any way I can get it to work in my 93 si? I've searched and found nothing. From what Little i did find, I've read the block casting is different and the tranny will not bolt up and work on any other h22. Is there anybody that has done this swap and got it to work? Basically my h23 has a bad crank and I picked up this full swap for 100 bucks, I know I can swap all the internals and head from the h22 over to my h23 block and make that work. I was also wondering if I could use the full swap and get some sh axles, or is it more complicated than that? Any help or info on this swap would be greatly appreciated.
Old Mar 12, 2011 | 07:02 AM
Tulsalude's Avatar
Default Re: 2001type sh swap into 93 si
put it on ebay and sell it that motor is worth at least a grand if its in good shape and buy a jdm h23a vtec
Old Mar 12, 2011 | 04:39 PM
minilogoguy18's Avatar
The money you'll be saving will just end up being wasted on a adapter to use a non SH trans, don't waste your money and just wait for something that isn't from an SH.
Old Mar 12, 2011 | 04:41 PM
dagle's Avatar
i have the halfshaft that will let you use the SH block with a base tranny. if you want it lemme know, it's collecting dust somewhere in my room.
Old Mar 12, 2011 | 05:59 PM
slowredsol's Avatar
Also, what exactly is the "sh" trim? Is it the all wheel steering? Or what is it?
Old Mar 12, 2011 | 06:14 PM
Hawkze_2.3's Avatar
SH means it has ATTS (active torque transfer system) which is contained in the transmission, and is basically like an intelligent differential for splitting torque between the front wheels. Check the FAQs or Google
Old Mar 15, 2011 | 02:45 AM
slowredsol's Avatar
Is there a company that makes the intermediate shaft for deleting the atts unit? Or are they all custom made? If anyone has any pics of theirs that would be vary helpful
Old Mar 15, 2011 | 03:25 AM
flyrod's Avatar
Pirate used to make an adapter plate, but I don't think there has been much demand for them any more. You can make your own or maybe talk him into making some more:
https://honda-tech.com/forums/honda-prelude-4/mounting-non-atts-tranny-atts-block-%2Asearched%2A-760082/
From the FAQ:
https://honda-tech.com/forums/honda-prelude-4/type-sh-base-comparison-why-sh-needs-its-own-block-code-%2Apics-inside%2A-1081801/
Old Mar 15, 2011 | 04:32 AM
1GPlusSH's Avatar
the ATTS is not in the transmission. it is a separate unit. it mounts to the block where the halfshaft mounts on a standard block.
SoFresh1189
Feb 18, 2011 12:03 PM
Turtle732
Feb 12, 2010 07:39 AM
84Luder
May 19, 2002 05:18 PM
M0NEYnH0s
Jan 29, 2002 08:36 AM
Sigma D
Jan 19, 2002 02:54 PM
