Brake pads for track
Old Mar 11, 2011 | 11:17 PM
natman316's Avatar
Default Brake pads for track
Hi all
I am replacing brake pads on my K20 Integra what pads would be good for a DD with some track day and auto x action? I am currently running stock calipers with brembo rotors.
Was looking at HP plus but I've heard they can be pretty loud when DD.
Old Mar 11, 2011 | 11:52 PM
racebum's Avatar
Default Re: Brake pads for track
hp+ or axxis ultimates will be your best affordable options. i actually like the ultimates more than the hp+ similar level of performance and quiet
you should upgrade to the 23T brakes. REALLY improves the overall of the car
Old Mar 14, 2011 | 09:03 PM
natman316's Avatar
i see I think I will go with the hawks base on reviews though
what is the 23T brake upgrade?
Old Mar 15, 2011 | 04:24 AM
Dogginator's Avatar
Daisy... Daisy...
Run HPS for daily, switch to HP Plus for the track. The compounds are compatable. I ran HPS on the track with 282mm rotors and the pedal was a bit too low for heel-toe downshifting. I had plenty of braking power, but did not like the pedal position. I shall run the HP Plus next time.
Old Mar 15, 2011 | 06:45 AM
vtecdc4's Avatar
hawks are good
Old Mar 15, 2011 | 10:39 AM
trevek10's Avatar
i run hawks on the track and switch um out for the dd .. just dont go to aggressive for yr daily or you will end up chewing up the rotors faster than usual.
Old Mar 15, 2011 | 10:44 AM
racebum's Avatar
23T are also know as the itr/accord v6/legend brakes
hp+ or ultimates will waste new rotors with one set of pads
just how it is, the hps are much more rotor friendly but don't offer the same level of braking or have nearly the heat resistance
GameBoyeas
Sep 7, 2017 04:58 AM
WhiteHonda
12
Jun 29, 2010 04:25 AM
blackapino85
22
Aug 5, 2004 02:13 PM
Yellow Dragon
Jul 16, 2001 02:58 PM
Ghetto Racing
Jul 4, 2001 07:24 PM
