Engine won't shut off
Old Mar 11, 2011 | 05:25 PM
dlc's Avatar
dlc
Default Engine won't shut off
Please help me diagnose a weird problem. I just finished replacing the engine in my 90 Civic wagon. The car cranked up fine and shut off no problem the first few times. Now, after starting the car, it won't shut back off. When you turn the key all the way off the engine lights stay on and the engine continues to run. I killed the engine by letting out on the clutch while holding the brake and I have to disconnect the battery cable to get the dash lights off. I'm thinking it's maybe a problem with the ignition switch but I wanted to ask here for advice first. Has anyone seen this happen before, and if so what was the problem. Thanks in advance.
Old Mar 12, 2011 | 09:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: Engine won't shut off
It is possible it is the ign. switch, to confirm, start the car, then unplug the ign. switch harness, there are two (2) plugs... http://cgi.ebay.com/ebaymotors/BECK-...Q5fAccessories
If engine stops, replace ign. switch. 94
Old Mar 12, 2011 | 05:01 PM
dlc's Avatar
dlc
Good info, thanks!
Old Mar 23, 2011 | 12:32 PM
dlc's Avatar
dlc
Okay, so I've been investigating a little more and have a new twist to the problem. I have determined that this only happens when the transmission is in reverse. When I select any gear besides reverse (manual transmission) the engine will shut off normally.
blade_frost
Honda CR-V & Element
Apr 6, 2012 04:07 PM
max7512
Jul 21, 2009 05:02 AM
IsiahCKL
Nov 14, 2007 03:14 PM
lord1234
Nov 1, 2006 07:00 PM
sgrahame21
Aug 31, 2006 08:31 PM
