Anyone know what throttle body this is?
Old Mar 11, 2011 | 09:33 AM
Cap'N Chronic's Avatar
Default Anyone know what throttle body this is?
When I bought my car the guy said the throttle body that is on it now sticks (it does..bad), so he threw in a new one with it. He said it was just a B-series throttle body but I'm not sure what it came from. For some reason I think it might be from a b16 off a civic si?
I need to find out so I can get the right gasket for it. I've tried like 3 different ones but none of them fit.
Old Mar 11, 2011 | 10:32 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Anyone know what throttle body this is?
obd2...
type r? b16?
what be the size cuz
Old Mar 11, 2011 | 10:38 AM
jayWknight's Avatar
its obd0, I see the fitv arm on the throttle body. Measure the opening to see how big it is.
Old Mar 11, 2011 | 10:53 AM
The opening is pretty small. Its like 5mm smaller than my B18B tb. Would this fit on my manifold? Or should I just get one off ebay or somethin?
Old Mar 11, 2011 | 11:18 AM
grumblemarc's Avatar
The Grumpiest
Did you take that with you when you went to get the gaskets?
Old Mar 12, 2011 | 09:04 AM
Nope this was after I tried like 3 different gaskets.
Old Mar 12, 2011 | 09:13 AM
raidacaipo's Avatar
Well look at the rivets on the Tps Sensor.. Its unscrewable meaning you would have to cut the rivet screws in order to adjust the Tps. My guess is that its likely an older model from a single cam of some sort. Check D series gaskets.. The B series throttle bodies especially from a vtec motor will have a Philips screw holding the TPS so that you can loosen it and adjust it..
Old Mar 12, 2011 | 10:53 AM
94EG8's Avatar
Seagull Management
That has nothing to do with D vs B-series, that's a JDM vs USDM thing. JDM engines used screws (they're not philips though, torx IIRC)
Xtream_V
May 30, 2011 06:41 AM
banks234
Feb 16, 2010 10:23 AM
toolbox21
Nov 27, 2008 10:21 AM
honda305
Sep 3, 2006 04:48 PM
gavhowe
Apr 22, 2002 07:18 AM
