Prop Valve install?
Old Mar 11, 2011 | 05:12 AM
CWBETB's Avatar
Default Prop Valve install?
Kinda a dumb question here. I just had Teg rear disc brakes installed on my hatch, I was using the Civic prop valve. Brakes feel so so, I hit a junkyard this weekend and just found a 4040 prop valve from a Teg. My question is, what would be the best steps to remove the prop valve from my civic without making a mess? Crack the bleeder on the front brakes or rear or both till empty? Then remove? I just dont want brake fluid squirting out and making a huge mess! Thanks
Old Mar 11, 2011 | 08:31 AM
Tyson's Avatar
Default Re: Prop Valve install?
Just use a flarenut wrench to loosen the fittings first. Put a rag underneath of course.
Don't drain the fluid before or any more than you need. No need to introduce any more air than necessary.
Bleed all 4 corners until it runs clean, and do another round to be sure.
Old Mar 11, 2011 | 08:36 AM
Davidss's Avatar
You can buy rubber brake line caps at your local auto parts store. They will slow the dripping considerably.
Old Mar 11, 2011 | 09:35 AM
CWBETB's Avatar
Good advice, Tyson thanks also!
CWBETB
21
Apr 11, 2011 04:25 PM
litterbox
18
Apr 7, 2005 05:56 PM
mingbling96
Dec 20, 2004 10:19 PM
crexer
10
Apr 17, 2004 09:13 PM
AThiker
Mar 4, 2003 06:19 PM
