mount problem h22 to f22
Old Mar 10, 2011 | 10:17 PM
Laskowski's Avatar
Default mount problem h22 to f22
Hi everyone, sorry to post this when the answer seems obvious, but i have searched for a bit and found nothing but F to H swap threads. I am putting an f22 out of a 91 CB7 into a 93 prelude that had an h22. ive done the F to H swap before but never gone this way. I am using the f22 trans also, not the H, the CB7 mount fits on the trans but is way too short, the prelude h22 mount wont fit on the tranny.
What mounts do i need for the F22 to fit right? all prelude f22 mounts?
I'm sure this is common knowledge to some of you but ive only ever had a 96 accord and put an H in that, it was pretty straight forward, just the drivers side mount and some wiring.
Please someone inlighten me
Old Mar 11, 2011 | 12:32 PM
Laskowski's Avatar
Default Re: mount problem h22 to f22
mmmm after doing some more research I have read that I must use the h22 trans, trans mount and back mount.
Or
find a F22 trans that came from 92-95 prelude
Is this true?
Old Mar 11, 2011 | 12:47 PM
SolScifen's Avatar
would a f22 tranny mount work? or you could try some fab work if you have the tools
Old Mar 11, 2011 | 03:10 PM
Laskowski's Avatar
the one that came from the cb7 with the f22 bolted to the trans, but was way too short so that side of the motor was alot higher than the drivers side, way to high. but yeah i read that prelude f22 trannys are different than cb7 ones
jimmy o.
Apr 23, 2013 07:19 AM
Luserkid
Dec 9, 2004 10:07 PM
OutlawCL
Oct 2, 2004 11:32 PM
OutlawCL
Sep 11, 2004 01:20 PM
