knock sensor?
Old Mar 10, 2011 | 08:38 PM
jaap_15's Avatar
Default knock sensor?
whats up guys im having trouble connecting the knock sensor from a 97 gsr on a 92 civic with and obd1 p72, i wanted to know what wire from the engine hardness is the knock sensor? i have researched and many say it red/blue but there are two red and blue wires which one is the correct one? Do i look at the driver or passengers shock tower? And last question, i know that the knock sensor should go to D3 but what do i do with the wire i removed from the D3 position do i just leave it out without connected to nothing? thanks
Old Mar 10, 2011 | 11:33 PM
apexi_rsx's Avatar
Default Re: knock sensor?
its the plug with one single red and blue wire.
Old Mar 11, 2011 | 03:12 AM
rhymeshark916's Avatar
What trim level is your civic?
Old Mar 11, 2011 | 04:14 AM
jaap_15's Avatar
I Believe it is the a dx... And what do you i do with the plug that is in D3 already do i just leave it unpinned and pin the knock sensor?
Old Mar 11, 2011 | 04:20 AM
No, it actually makes your life easier. So there's a wire in there(d3) correct?
Old Mar 11, 2011 | 04:28 AM
jaap_15's Avatar
Yes there is..how would make it much easier do use that?
Old Mar 11, 2011 | 05:31 AM
Red_Army's Avatar
you should be able to just cut and solder that wire to your knock sensor wire.
does the wire in d3 go anywhere right now?
Old Mar 11, 2011 | 05:35 AM
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRES FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
BLU/YEL - KNOCK SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
REMOVE THE RUBBER PLUG FROM THE TWO UNUSED SOCKETS
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
INSERT THE BLU/YEL (KNOCK SENSOR) WIRE INTO THE SOCKET NEXT TO THE OTHER BLU/YEL WIRE. (BOTTOM RIGHT SOCKET IN PIC)
NOTE - IF YOU ARE USING A CHIPPED P28 ECU YOU WILL NOT NEED TO WORRY ABOUT WIRING UP THE KNOCK SENSOR
Old Mar 12, 2011 | 08:16 PM
jaap_15's Avatar
Im sorry guys i miss informed you there is no wire on d3, so what size wire do i use to run from the knock sensor to d3? And is there 2 locks on the plugs to be able to depin?
Old Mar 15, 2011 | 11:39 AM
jaap_15's Avatar
hey guys i have someone that is selling me a p28 ecu that is chipped for a b18c1, and the knock sensor is disabled, and he said what i would need to do is to remove the iabs or get a skunk 2 intake manifold, and wire vtec but since i have a 92 civic my model is already prewired for vtec, is it a good deal for $110 or should i just stick with my p72? and would it be hard to remove the iabs? thanks
Old Mar 15, 2011 | 06:59 PM
jaap_15's Avatar
Help?
Old Mar 15, 2011 | 07:08 PM
apexi_rsx's Avatar
it would be better to run a chipped ecu u can always get it tuned and the knock sensor is pointless and you would be better off without it. goodluck
Old Mar 15, 2011 | 07:18 PM
jaap_15's Avatar
So i should get it?
Old Mar 16, 2011 | 09:51 AM
sextav6's Avatar
say what?
Old Mar 16, 2011 | 02:38 PM
Go with the chip p28. Sell your p72, pretty rare.
Old Mar 16, 2011 | 02:49 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by sextav6
say what?
If you get it tuned then the knock sensor is not an issue.
Old Mar 21, 2011 | 09:14 AM
sextav6's Avatar
but knock sensors are not pointless, quite the opposite. a knock sensor can save a motor
Old Mar 21, 2011 | 09:19 AM
The Grumpiest
And if the engine has no knock sensor but the ECU is looking for one?
Old Mar 21, 2011 | 11:25 AM
sextav6's Avatar
obviously if the engine has no knock sensor, then it isn't pointless, its nonexistent. however, b18c1's have a knock sensor, hence this discussion.
Old Apr 1, 2011 | 10:43 AM
jaap_15's Avatar
i hooked up a pin in D3 and ran a wire to the passengers side shock tower but i dont know which wire do i get for the knock sensor, there is a plug that is plugged to anything but i have searched and some say it is for the secondary o2 sensor, so which wire do i cut into for the knock sensor? I'm running an 97 gsr engine hardness...
Old Apr 1, 2011 | 01:19 PM
jaap_15's Avatar
Any suggestions?
Old Apr 2, 2011 | 05:21 AM
Run the wire from D3 to the corresponding pin on the shock tower/red/blue gsr harness wire.
Old Apr 25, 2011 | 01:23 PM
jaap_15's Avatar
I ran the wire to d3 and I still have a check engine and vtec doesn't kick in strong
Old May 2, 2011 | 03:03 AM
jaap_15's Avatar
help please
Old May 2, 2011 | 11:38 AM
You need a new ks. You have to make sure your cel is clear.
