ceramic coating
Old Mar 10, 2011 | 04:37 PM
SR20S13's Avatar
Default ceramic coating
so i've got a bisimoto header that has a ceramic coating, but i now need to weld a 2.75 to 3 inch transition onto it, but in order to weld i need to remove some of the ceramic coating, should i just wire brush it off or would something like aircraft paint stripper work?
Old Mar 10, 2011 | 05:21 PM
MD426's Avatar
Default Re: ceramic coating
Just wire brush off the area you need to weld.
Old Mar 10, 2011 | 05:42 PM
SR20S13's Avatar
yeah i guess whats what i'll have to do shouldnt be that hard
Old Mar 10, 2011 | 06:28 PM
cibao2ner's Avatar
why not bolt the transition..weld a flange to match the bisi header and then just do a bolt on 2.75 to 3 inch test pipe..
Old Mar 10, 2011 | 06:45 PM
SR20S13's Avatar
well the header was made to use with a 2.75inch donut gasket and then floating flange, and no one makes a 2.75inch floating flange, i mean i'll try calling bisi again but they just say "bring it to a muffler shop or weld this pipe on" so i mean i could try just getting a 65mm floating flange and trying to make it bigger to fit over a 2.75inch pipe
nyckid
10
Dec 22, 2015 09:04 AM
DA9nEF9
Welding / Fabrication
Oct 1, 2014 07:03 PM
Rok_Stok
Nov 7, 2009 10:42 AM
jdm_ef9
18
Apr 4, 2005 03:54 PM
-Whitey-
Jan 27, 2003 11:58 AM
