what the frak is this plug (under dash)
ok so iv had this eg apart completely a few times. there is also a kswap in it now...all of a sudden..i see this plug under the dash...where does it go?
there is no other spot in the fusebox and the instrument cluster doesnt work.
the cluster has both plugs in it. for the 34rd time i dont wana take the dash bak out
any ideas...?
any ideas...?
I'm about 99% sure that plugs into the back of the fuse panel. If you still don't have it figured out by tommorrow i'll try to get outside and see if I can figure it out, I have some spare cabin harnesses and fuse panels here so I should be able to sort it out.
Ya. Wats the icu? the main relay is plugd in. iv driven the car today.
i hav no heater. climate control. radio.
its a dx with alot of the excess wire taken out from the rear defrostr n rear speakers etc
ICU, black box about the size of a deck of cards, plugged into the back left side of the fuse box. The plug/connector is on the far left side, the release pin for the connector faces the left as well.
i looked @ it at least 67x but automagizikly appeared
thanx guys
tearlessj
Sep 6, 2011 08:41 PM
sh!tsWEAK!
Feb 24, 2007 01:15 PM
b16ferio
Feb 24, 2004 08:35 AM
