what r those plugs?
Old Mar 10, 2011 | 08:48 AM
ricanxplaya's Avatar
Default what r those plugs?
i have jdm b18c motor on civic 99-00 ek, i believe the wire harness is either ex or si from 99-00, i cant know for sure because, i bought it off from here. but anyway i tried to look at the manual book on wiring color and what they are but i cant find what they are! please help me out if u know what they are. i just think that one of them is iat sensor but the color is not the same. and the other one wht/red and blu/red i have no absolute idea!
Old Mar 10, 2011 | 08:56 AM
Default Re: what r those plugs?
i have another question with iat sensor because i know there is one on the intake chamber before throttle body and then there is one on top of manifold runner sensor ? what r difference between those two?
Old Mar 10, 2011 | 08:59 AM
Dontoh's Avatar
i want to say that plug goes onto your power steering, but im not 100%. i think mine is green, looks the same though
Old Mar 10, 2011 | 09:08 AM
my power steering is already plugged
Old Mar 10, 2011 | 09:09 AM
Dontoh's Avatar
where does it come from?
come from what?
Old Mar 10, 2011 | 09:10 AM
Dontoh's Avatar
if you follow the wire, where does it go
Old Mar 10, 2011 | 09:19 AM
its on left engine bay are under manifold its just hanging with no where else to plug in.. or i may be missing something.
Old Mar 10, 2011 | 09:29 AM
can anyone tell what they are by color wire? i cant find it on hayness and dealership manual
Old Mar 10, 2011 | 09:35 AM
chrisdavis6's Avatar
the 1st round plug looks like the IACV plug.
Old Mar 10, 2011 | 09:41 AM
my iacv is already plugged. but i m going to check again if it is the correct plug to iacv.
i will tell u which of the following are plugged.
map, tps, iacv, cts, psp, ho2s, ks, alt, vtec, dizzy, i may be forgetting somethings.
i have not plug iat ( my iat is missing and need buy one for intake chamber) but i have iat sensor on top of my manifold, but i dont understand why will i have two iats?
Old Mar 10, 2011 | 11:39 AM
94EG8's Avatar
Seagull Management
First plug: Vtec pressure switch
Second plug: CKF plug
Old Mar 10, 2011 | 12:29 PM
JDMAF's Avatar
At some point someone switched out the intake manifold... that one will work fine... either or will work fine... pick one and go with it...
Old Mar 10, 2011 | 12:30 PM
Akiyama's Avatar
IACV plug, second one looks like the horn plug.
Old Mar 10, 2011 | 01:28 PM
vtec pressure switch is one wire, arent they? where is ckf located on b18c?
Old Mar 10, 2011 | 01:44 PM
94EG8's Avatar
Seagull Management
No, see my above post. I didn't guess I went through the wiring diagram for a '99 Si.
Nope, 2 wire, knock is a single wire, same style plug.
On the oil pump. If it's a JDM engine it wont have one.
Old Mar 10, 2011 | 01:48 PM
i see. yes its a jdm b18c. thats why i dont have neither vtec pressure switch nor ckf switch. so then i shouldnt be worried about those two plugs.
Old Mar 10, 2011 | 01:55 PM
94EG8's Avatar
Seagull Management
Exactly, so long as you're using the matching JDM ECU.
Old Mar 10, 2011 | 02:04 PM
good to know now. thanks guys
EJ8CIVIC
41
Dec 10, 2014 12:34 PM
neroren
Feb 27, 2010 11:28 AM
killa4lyfe
Jul 11, 2008 08:44 AM
tuan...
Sep 23, 2004 11:48 AM
CunninLynguist
Nov 9, 2003 09:10 AM
