intake manifold from d16y8 fit a d16a6?
Old Sep 26, 2002 | 01:20 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default intake manifold from d16y8 fit a d16a6?
i've heard of this before but i wanted to check to be sure. also does a 90 and up integra throttlebody fit on the 96 and up d16y8 manifold? i don't want to do a mini-me or spend much on the a6...saving for a b16a swap.
Old Sep 29, 2002 | 04:37 AM
wronghand's Avatar
Default Re: intake manifold from d16y8 fit a d16a6? (fastcrxsi90)
The Y8 manifold will fit on the A6 head. And the Y8 manifold has the same throttle body bolt pattern as the b-series. So the 90+ integra throttlebody should fit.
Old Sep 29, 2002 | 05:53 AM
4gvtec's Avatar
yes it bolts up.the only thing is it has to be from a 5 SPEED ONLY!!!!!!!!!!!!!!!
you have to find a new place for the intake air temp sensor,theres no place for it on the manifold.any where from the filter to the throttle body is fine.
Old Sep 29, 2002 | 06:52 AM
wronghand's Avatar
Default Re: intake manifold from d16y8 fit a d16a6? (4gvtec)
What is the difference between the auto and the 5 speed? Is it simply the vacuum lines or is it more extensive?
Thanks.
Old Sep 29, 2002 | 08:48 AM
SOUTHCREX's Avatar
Default Re: intake manifold from d16y8 fit a d16a6? (wronghand)
OK, will someone tell me the diffrences between these two? http://cgi.ebay.com/ebaymotors/ws/eB...tem=1863970590 https://honda-tech.com/zerothread?id=288612 these are obviously two diffrent manifold's witch one is auto and 5speed?
Old Sep 29, 2002 | 09:08 AM
Malgerus's Avatar
Default Re: intake manifold from d16y8 fit a d16a6? (TEAM GARAGE SHIFTDOWN)
They both look like manual transmission intakes. You can tell by the location of the IACV, which is on the intake manifold for the manual version, and on the throttle body for the automatic. The ebay is difficult to see, but the second one is definately a 5-speed one.
Old Sep 29, 2002 | 09:17 AM
slowman's Avatar
I took way too long
Default Re: intake manifold from d16y8 fit a d16a6? (89_Y_49RIP)
good info in this thread i was curious of that too. i have the y8 t/b now i just need to find a y8 mani
Old Sep 29, 2002 | 02:17 PM
SOUTHCREX's Avatar
Default Re: intake manifold from d16y8 fit a d16a6? (slowman EF)
I noticed that first IM has vacum right where the IM conects to the head, but the ebay one dose not, anyone know where that vacum gose, And can that help identify the manual from the auto?
titi_vtec
Jun 29, 2010 07:59 PM
matt21civ
Apr 20, 2006 10:00 AM
civic nation
Feb 28, 2006 05:54 PM
letholone
Jul 6, 2004 01:09 PM
