B18c
Old Mar 9, 2011 | 09:19 PM
00em14life's Avatar
Default B18c
How can you tell if a jdm b18c is a gsr or a type r motor?
Old Mar 9, 2011 | 09:51 PM
raidacaipo's Avatar
Default Re: B18c
Big give away is the intake manifold. Search it and youll see why. A type R manifold will not fit in a Gsr head so most likely the Gsr will either have the stock looking intake manifold or an aftermarket brand which looks similar to a Type R manifold.
You can also look at the throttle cable bracket. The gsr will tend to stick up whereas the Type R bracket stays low. I cant really explain it but if you look at pics you can see what I mean. This only applies for stock gsr manifold
Other factors include the header however, I ruled this out because the type R header is interchangeable with the Gsr head so you cant really tell. However, the intake manifold is non interchangeable
Old Mar 10, 2011 | 01:28 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: B18c
Intake manifold can be swapped easily with look alike designs, the best way is to simply look at the cylinder head stamp!
P72 - SiRG, same as gsr
PR3- has either a B16 or Type R head on it, and the intake manifold willl be stamped P73 on the back of it
Old Mar 10, 2011 | 04:46 AM
CivicBlacksheep's Avatar
10 Year Member
Default Re: B18c
^ gsr- p72....type r-p73 on head
Old Mar 10, 2011 | 04:53 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: B18c
The Gsr intake manifold is a dead giveaway. That manifold also only fits on the p72 head.
Old Mar 10, 2011 | 10:24 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: B18c
no such thing as a P73 head, they are all PR3, just like the B16A
Old Mar 10, 2011 | 10:25 AM
Ek Forever y0!
Default Re: B18c
Correct, the b16 and ITR heads were the same part number IIRC
Old Mar 10, 2011 | 08:16 PM
00em14life's Avatar
Default Re: B18c
alright thank you guys
Old Mar 10, 2011 | 08:55 PM
UncleD's Avatar
Default Re: B18c
Water neck is also different...I know it's dead, just sayin.
SpoonCivicSir20
Sep 12, 2009 03:30 PM
racericky
Dec 4, 2006 05:00 PM
jdm2teg
Oct 11, 2005 09:52 PM
ahh sanga
Dec 10, 2004 10:54 AM
gots_a_sol
22
Apr 11, 2004 05:57 PM
